lol probably not.
Hard to know how it stacks up against a Naprec DET head, but it's titanium retainers, Kelford beehive springs, hks gears, ported, supertech IN and EX valves (standard dia, just stronger/lighter).
P12 head, but with P11 valve stem sizes as they are stronger, oh and Kelford cams but still retaining VVL.
Should go "ok", I hope so coz it cost a few bucks.
Edited by ActionDan
  • Haha 1
Just now, Dose Pipe Sutututu said:
Don Mega Dim Sum Bing Bong Spec head, love it.
Is it also going to a stock bottom SR20? ?
Nah have upgraded water pump to NASA spec and using blue pulley on it too!
LOLOLOL Space-X quality, none of this use once throw away business
  • Like 1
There is some custom Space-X in the bottom that I am not allowed to share pics of.  Head also has the mazworks headstuds because they bottom out properly (Fairly sure they are just Golf head studs with the right length) and got an expensive as f**k Cosworth headgasket.
Re the bottom - apparently Nismo provided DM with the technical specs of the SR that was in the JGTC car he had which included some changes to the bottom end for longevity that DM now uses on his builds (if you pay the iron price). I'm sure any competent builder is already aware/does it/wont do it because it's gay or whatever, but he asked me not to share pics so I wont.
He told me about the changes and showed me how it all works and I said "Yes, give me the stage 1 e-fame package plz".
So I am expecting bulk likes and plenty of Grinder invites.
You guys already know I bought those Nitto I beams, CA625 rod bolt upgrade, CP pistons, Plazmaman girdle, ATI balancer, all the ARP bolts etc.
Using new OEM VE oil pump and an aeroflow big boi sump but I'm also looking at a dry sump kit he has because scope creep is f**king insane.
Edited by ActionDan
  • Like 1
  • Haha 2
Sorry guys, I just got here. Is this... Is this the Bakemono thread? I can't work out where is the bants and where is the proper build specs. Dan, can you confirm if blue pulley is aerospace alloy? How many fuel pumps are in here, 5? 6?
Seriously though. I'm feelin ya on the scope creep Dan. Somehow you go from mentally preparing for weeks to spend $2000, to just giving strangers your credit card details without even asking for a price first.
  • Haha 2
Probs just upgrade the pump on the side of the surge and call it a day?
Dunno how much fuel the stock lines can supply, haven't bothered looking in to any of it.
Not even sure I want e85 due to the hassle getting it here. They did put a pump in at the new United on the highway, but I have no idea if that's still going.
Flex sensor I guess.
11 minutes ago, ActionDan said:
Is that the limit?
I'm not quite sure to be honest, however with 1x 460L hard wired in running at 13.8V with the FPR fully wound out, the fuel pressure was still about 2bar.
Now with a 8AN feed from the surge to rail, and using both stock feed/return as a merged return I can get the fuel pressure down to under 1 bar.
If you use a stock fuel system in this I will be so disappointed, basically getting the fuel to the engine for constant HP is critical
In 3rd gear I’ve chopped both an Audi RS5 and C63 AMG, I’m talking several car lengths
you need a fuel system for track work!!!! Put a flex sensor in it then you can run pump and E85!!! But getting a surge tank right is a black art I have all the secrets to get it right
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
