You could give Andy @ Maddog Customs here in Perth a ring and speak to him about building a kit cage that you can then have shipped to you and welded in. I know he was looking at doing this, he hasn't done it yet but he may be open to that. He has atleast built several Silvia cages, so he should have the drawings in his software and be able to do it.
Never know, worth having a chat to him about it.
Brown Davis sending me bars for under 2k doesn't sound too bad as I have some mate's who are very good welders, but I am likely underestimating the work involved as the do not send then notched just bent.
Anyway, let there be lights!
The hanging lights are over the workshop area and the centre post light is to shine down into engine bays for cars in the hoist spot.
So much cleaning up to do 0_0
Only thing left to wire is the hoist plug, but I'll get the hoist in place first.
  • Like 4
Shed company won't tell me because they don't wanna be liable but who can help me work out load limits for that apex brace in my shed?
shed spans 10m and these are the details of columns, apex and knee braces/fixings etc.
I wanna use a pulley block or a block and tackle etc to help me stand the hoist columns up - which would way 250-300kg each.
Whipped around and did some quick cleaning last night, I'll do a proper clean up after hoist is installed prior to moving my shit in.
Tested all my power points, all OK, tested power to roller door motor, moves around a bit so that's a good start, need to set door limits.
Started unpacking the hoist, forgot I'd negotiated a oil container also. A bit plasticy but it was free.
Ready to bring the engine crane in and start unbolting the columns from the shipping frame.
Initial inspection is welds and paint look good.
Edited by ActionDan
  • Like 1
Shed builder thinks the frame/apex brace could handle one column at a time, but pushing the shed company and their engineer for more info.
Went through the bits and pieces last night, of course the dynabolts are 18mm and I only have 16, 20, and 24 in masonry bits - Went to Bunnings this Morning and grabbed an 18.
Brought he engine crane in and had a fiddle with strapping/positioning and got as far as removing the frames and taking the weight of one column but found I had not positioned far enough down the column, they are VERY bottom heavy, so put it back on the frame to reposition and ran out of time.
I'll head back down in the next few days with some more/better straps also and go from there.
Also configured the roller door so it's now going up and down nicely.
Frame up and have run cables and hose between both columns and mounted the motor. I'm working on safety mechanism now and going through everything and tightening it all up, making final connections, etc. Still need to mount arms, finish the wiring for the pump (circuit and lead in is already there), fill with fluid, tension cables etc.
My engine crane was indispensable during this process, used it to remove each column from the trailer and then stand each column up - with the help of a mate and strapped to a shed column for extra insurance so it didn't get away from us as we stood it, but honestly I could have done it solo with the engine crane, thanks for the tip Rob.
10x 18mm holes at 150mm gave my batteries a good work out in the rotary drill and took a little time but got there eventually. Even busted out my toque wrench as per the manual on those.
I was proud of myself for getting that cross bar up solo, used a combination of the winch and a pulley block then some ratchet straps to go beyond the apex brace to a point where I could just lift it up the final bit at each end. Having that portal frame there was very convenient and the columns clear it perfectly, safety will be below it. The shed was also spec'd to stand without that apex brace so if it's ever a clearance issue I can remove it (note the extra strapping in the hoist bay, plus we went cast in brackets for the frames vs dynabolts).
I took an extra long time to level and square the columns before I started drilling, marked the plates on the floor, drilled, checked, drilled again etc so to have the cross bar pop in nicely, and everything torque up easily and stay level and square was very satisfying - my poor mates were getting more updates than they would have liked in our group chat lol
I'm looking forward to having this done so I can get stuck in to moving in, get my pot belly in etc.
Also check out this baller tool box I picked up on Facebook for $150. Pretty happy with that.
194279050_782312769107237_1632853102687295617_n.thumb.jpg.e53a26f5c290b1ffada608833dd430cf.jpg
  • Like 2
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
