Hello,
So today I was driving and some guy told me to pull over and started talking about my car. He said my revs are too slow coming down after letting go of the accelerator.
I think its ok but it would be cool if it went down quicker i guess just for sound but anyway.. would that be a flywheel change?
https://www.sau.com.au/forums/topic/472343-change-flywheel-quick-revving/
3 hours ago, AusFreak said:
Hello,
Well theoretically a heavy OEM flywheel will want to stay in motion longer. A lightweight flywheel should change the rpm response but it can also have an effect on idle.
Im assuming this wasnt someone you knew? I think thats an odd thing to have happen personally haha.
nah i was driving and this guy told me to pull over and he was talking about how the do up cars n stuff like that. Because im overseas they use russian words for every car part so i couldnt understand him well.
So if i put in a lighter flywheel would their  be any cons to that for example, break? :P
When I made the change, it required a slight change to the way I walked off the clutch. Button clutch, so it slightly increased the chances of a stall.  So use another couple hundred rpm at the engagement point.
Otherwise it was all positive.  Engine felt more responsive to throttle changes (but not by a huge amount - you get used to it so quickly it becomes the new normal).
Made a relatively sporty car feel a little more sporty, IMO.
4 hours ago, Dobz said:
Gauging from the last paragraph of your first post, no you don't need a lighter flywheel. It'll just make it less pleasant for you to drive around the streets.
Exactly! Haha.
I found the idle to be a little more all over the place and honestly the clutch was a lot more touchy. Its great on a race track but not so much on the streets.
That said a lot of people dont mind driving a lightened flywheel
Lightened flywheel is fine but I'd only bother with it if already doing a clutch change etc.
Yes it will make engine speed decrease quicker. It will also make take off proportionally harder / require more revs because of less kinetic energy stored inside it to get the vehicle moving. So I wouldn't recommend it for a daily driver with a button clutch in bumper to bumper traffic. As mentioned before, idle can be less stable too and may not be happy below ~1000rpm, depending how light it is.
This ^^ +1
There's a fair bit of effort to pull the box, and you wouldn't put in a lighter flywheel without correspondingly more serious clutch setup.
And if it's a daily driver in heavy traffic then forget it.  Actually, still do it, but buy an automatic Hyundai for the heavy traffic grind.
  • Like 1
i wont be changing it, like i give a F what some random on the street says. I got one of the kick ass cars in this country (Armenia) i'll be working on other things.
Story time:
Last night i went to a car shop where lots of cool cars usually are too see whats up and they saw my skyline and they made a call and another skyline showed up within 60 seconds and they had said they had seen me in the city but people didnt believe him haha so anyway we hung out and all these hotted up cars showed up, yeah was fun. Got some new cool friends, rare to find people that know stuff and are into cars here.
  • Like 2
Interesting to hear that sort of camaraderie which I think people take for granted here. Even as imports are getting rarer and rarer, people here still don't even wave at each other as they drive past.
God damn street racers
  • Like 1
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
