4 minutes ago, discopotato03 said:
It occurs to me that Garrett are taking a long time to bring larger versions of this G Series to the market .
Its time they got their finger out in my opinion and had a look at bringing out the next turbine size up in the G series .
Keep an eye on the end of year trade shows
  • 1 month later...
Yeah they are clearly an improvement over the GTX series, though if you look at the most recent result added to the EFR thread of the EFR7163 on an SR20 it makes it seem like there is more catching up to do to get to EFR status - granted the 7163 is probably the best performer "per pound" of the EFR range.
52 minutes ago, discopotato03 said:
I reading a few claims at various sites that Garrett may have the G30 on show at SEMA .
Anyone know anything about this ?
A .
Yeah, I've been saying for a while that all the noises I heard suggested that they intended on releasing the rest of the range - and have certainly not heard anything to suggest that doesn't still apply.  There seems to be a fair likelyhood we'll see G-series "up to 1000hp", which presumably will mean up to around 90lb/min turbos.
I'm patiently waiting too, if they are going to take another year I will end up biting the bullet and getting a GTX3582 Gen 2
But from the testing done by Sasha the G-Series turbos look very impressive.
I was conflicted about it tbh, it looked much better than the out-going Garrett turbos however - if you compare his SR20 result with the SR20 result posted for an EFR7163 in the Borg Warner thread recently it leaves things looking like the G25-framed turbos may be overshadowed by an old dog.
BW EFR hands down are quite the performer - however their resilence to abuse isn't that high as many have experienced. So for me the Garrett brand (as much hate as it gets by certain people in SAU - not you, others) tends to be the best option not to mention I get better pricing for them too :D
In other news, still need to get my car running properly first and give Tao some data I promised him about 2 years ago LOL
  • Like 1
I'll reserve judgement until the G30 and 35 are released and the market gets to test them . Garrett is obviously putting them up against the older GT versions and the market will soon know if they aren't much if any better .
I'm most interested in the G30 and how it goes response wise compared to the GT3076R/GTX3071R . I'd like to see a bit less inertia and a bit better wheel efficiencies , in other words same power as a GTX3071R with better spool .
A .
A .
I'm going to put my neck out here and say I'd bet a cheeseburger that if there is a "wheel size equivalent" of the GTX3071R that the G30 will not spool as well.  I think with a lot of turbos, ESPECIALLY the G-series you need to pay attention to the flow levels provided and compare response with other turbos which provide that amount of flow.
I would view it that the flow efficiency "mm^2 for mm^2" is much higher, while the response "mm^2 for mm^2" is a bit worse.  If you want to compare a G-series with an equivalent GTX-series for response, compare the G25-660 with a GTX3076R - it'll be hard to get a much closer comparison between two completely different series of turbos.   If you want to compare the G30 with something to get a gauge of the response improvements, you should be comparing with a GTX35-series turbo.
That's how I view it, anyway.
Edited by Lithium
Day one of SEMA and Garrett have unveiled the new G42 1200 and G42 1450 respectively with new turbine wheel and aero plus stainless steel turbine housing. These will be available in Australia next year, pricing is yet to be confirmed.
https://www.facebook.com/GCGTurbosAust/?__tn__=%2Cd%2CP-R&eid=ARBjacV7wG2nImRs247yR4OIQWNGQzawsgn9Nh5Q0DiNuf8l661e8PnE92xc6mLc6PblK3OBaFHPbTNm
45081590_1941165239282163_14082468263388
45027288_1941165269282160_38838666071134
  • Like 1
Those look pretty grunty but I'm quite disappointed that they are putting across the impression that the two G42 releases are the only new G-series being released at this time, it's really missing the mark of what people are looking for.
Borg Warner on the other hand have quite possibly nailed it
  • Like 1
  • 4 weeks later...
bit the bullet and went with a g25-660 .92 external gate on the sti. ej25 on e85. will post dyno results when I have it on there. wont be till after xmas.
compared to a similarly rated efr that's in the shop, its nearly half the size. (don't know what efr exactly, but told its only rated to 750hp)
this replaced a twinscroll td05 20g setup. have to say with a very basic road tune to make it driveable and zerod wastegate duty. it starts to make boost earlier than the twinscroll setup. it also made 15psi by 3k rpm. again, zero duty and a very rough tune. to say im excited is an understatement. will report back when link is installed an tuned.
  • Like 2
17 hours ago, discopotato03 said:
Well if the G30 is going to be how some here expect it to be then I can only hope there will be a G28 , or a least a G28 turbine option . Sort of like a 6758 wheel size wise but less bulky .
That's pretty much what the G25-660 is.... except with EFR7670 flow
  • 1 month later...
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
