The particular ATR43SS-2 is a 2019 built model. I'll be happy to upgrade to current model free if you are keen to do further comparison work.  Or whoever buys it that want to update shoot in an email.
Edited by hypergear
very good and generous offer, thank you. Don't think I'll have the time or funds to do this but, appreciated.
The Garrett supercore is on now and, trying to remain impartial as I didn't have any expectations of ' difference", or dyno results for exact comparison but, does feel like the genuine Garrett has a bit more torque to it than the Pulsar turbo.
one area to compare for genuine garrett vs pulsar is wheel to housing clearance.  the smaller the gap the better.  i saw a pulsar in person and it had one of the largest gaps ive seen for a ball bearing turbocharger
Edited by Full-Race Geoff
  • 1 month later...
Great reading here.
I am just in the process of buying a new turbo for my 26/30.
Im only after about 500 whp with killer response max rpm about 7000-7500
I was lucky enough to pick up an old hks split pulse manifold ( low mount with top mounted wastegate)
Cant make up my mind between a g30-770 or a g30-900 with a .85 divided manifold . Im really open to what every one thinks, im looking for and would appreciate help . I did look at the efr but its impossible to get them at the moment.
Thanks mate. It’s kinda where I am headed.  I appreciate any feedback of some one who has tried it.  I really wish they did a t4 twin scroll internal wastegate for that turbo.  Would make my mind up instantly.
You can get a t4 twin scroll rear for it from atp in America, barely anyone does internal gates on twin scrolls because they are a massive compromise. If you’re going to expense of going single you may as well do it properly with external gates and etc
  • Like 1
I was going to say the 900 also. The 770 would probably do it, especially seeing as you're proposing to use the same exhaust housing whichever way you go. But the 900 should still rip on a 3L bottom end.
But, A word of caution. Will you be able to fit that turbo on the low mount HKS manifold? There's not a lot of room down there for a biggun.
Is the top mount wastegate offtake common to both halves of the manifold? If so, then that's a bit shit. Kinda ruins the point.
What would be the disadvantage of a modern internal waste gate
No it’s divided all the way to the top. So until the wastegate opens it a fully divided manifold.  Good point on the space thanks for that.  They ran a t04z from hks so I think they were a big turbo in size
I can’t find that housing on atp
You will need to cut out part of your rubber engine mount.
I tried running a gt3076r but it fouled on my chassis rail (S chassis)
I hope not to have to do that. Its in an r32 where it came from, not saying it will fit but Im sitting here with crossed fingers
https://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-HSG-637&Category_Code=GTHG35
took 3 seconds to find
So this is kinda relevant to this conversation, someone else have mentioned non-Garrett options so I feel like its not MILES from being appropriate to mention anyway as this suits the turbo matching concept and also possibly offers a housing option if you go genuine Garrett G35 900 core.
A mate with a GT-R which was running twin -5s on an RB26 with Kelford 272s had one of the turbos fail recently and it was going to be annoyingly hard work to replace when he already was aspiring to put an RB28 in it and go single turbo at some point, probably the likes of an EFR8474 when the budget allows but he was not ready to take it off the road.   Some big yarns were had about what would be the most rewarding way to get it running now but also not result in too much back tracking in the future.   The target was be at least as good as the -5s, fairly typical low mount twin setup with just over 500whp on 98 and full boost in the late 4000rpm range.
After much discussion around things like G30s, going straight to EFRs etc the budget right now wasn't suiting so partly to get it going sooner but also just to try something different he went with a Pulsar G35-900 copy with a .85a/r divided T4 housing.   Hoping it will be going in a couple of months or so with the divided housing, I can report on how that goes but I do realise people view the Pulsars as not at all a comparison with Garretts and the T4 hotside isn't even an option from Garrett, but I mention it partly because Pulsar *do* do a .85a/r T4 divided hotside which in theory should suit a G35, genuine or copy.
The Pulsar will at least be on there to get it running until an EFR/RB28 build can be sourced and delivered - though if the Pulsar performs too good it may stay in there longer haha.
Edited by Lithium
  • Like 1
  • Thanks 1
It's a 3L block so he might have a little more vertical clearance to help with the engine mount, but I'd still worry about the space to the side of the engine bay.
The problem is you have 2x small flaps instead of 1x large one. For the space available and taken up by the 2x small flaps, you can't get anywhere near as much flow area as you can in a single scroll setup. So there's not really any such thing as a "modern internal wastegate" where they description is expressing some hope that they've managed to improve the design of something that has almost no improvement available.
  • Like 2
1 minute ago, r32-25t said:
Can you now find one with an internal wastegate ??
Did you read the rest of my post? Do it properly and use external gates, there’s no such thing as a modern internal gate and they don’t work well anyway
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
