2 hours ago, Dose Pipe Sutututu said:
Hey relaks brah, my engine hasn't gone bang yet, however the motivation has.
You don't really have a lot more to do, do you
Just fire that puppy up and go for a cruise in the mountains or something
The sound of a RB, on boost, reverberating off walls should bring your boys back to the yard, if that doesn't stir the loins then all hope is lost.
Might do a track day next month, let's see if it goes bang then lol.
Because nothing breeds motivation more than breaking your car at the track.
For my sake, start slow
Or, go balls to the wall and post video
I has Pssshh for the LOLS
Only opened a bit currently so only minor LOLS, I tried it everywhere from 100% which brought all the bangs to the exhaust and PSSSHHH to the extreme, right down to closed with nil psshh's
Spring is wound down pretty tight, so only really vents at max boostage, under that its very minor dosage
LOLS are pretty good
  • Like 1
Still not broken
Fuel pump, injectors, Flexfuel and clutch
  • Like 3
  • 3 weeks later...
Contemplating a catback or axle back.
Car sounds stock, except for turbo spooling and tyres slipping.
Conundrums:
1. Pre fab - Invidia? N2? R400?Cold start noise?
2. Shop made - pretty much design what I want with the sound I want.
1. Pro: Would be cheap and I get to install, Con: get what I get given sound/drone wise
2. Con: Would be a bit more expensive vs the massed produced item, Pro: able to test what it sounds during the build, Con: I don't really get to install.
2. Found this axle back pic on the nets, will need to speak to my local exhaust shop, Pro: stock rear pipe and resonator, stock exhaust tips, Con: Cost???, not really any other cons that are blinding obvious.
Disclaimer: this is not a performance modification, pipe work can still be the same as now, just need to do something about the mufflers, I'm after just a little more sound.
I keep leaning towards shop built....like the pic
Hmmmmm
29 minutes ago, Dose Pipe Sutututu said:
External gate, I can supply Turbosmart gate
LOL, yeah nah
I had a "screamer" pipe on my 33, for about 3 days, till it got plumbed back in, it sounded like arse.
1 hour ago, Ben C34 said:
Turbos car to make it quieter, Nek minit..
Yeap, I'm a idiot.....
I swear to jebus I'm one of rhe stupidest old hoons on rhe planet.
I blame all the pot I smoked as a teenager.
Becauseconsumer
Plus I haven't been under the car for ages
1x KDT926 Whiteline Front Gearbox - Mount Bushing (BRZ/86) $35.37 $35.37
1x TS-FRS-Rear Torque Solution Rear Shifter Bushing: Toyota 86 $37.36 $37.36
1 hour ago, mlr said:
I'm fairly free this weekend
Go with @PLYNX this wekeend is mental for me :(
Tomorrow cake delivery (missus side hustle), then accountant, then planning out our bathroom reno with the builder, then buy shit, then going to Hans Zimmer symphony (because all Skyline owners are sophisticated LOLOLOL)
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
