2 hours ago, Dose Pipe Sutututu said:
Hey relaks brah, my engine hasn't gone bang yet, however the motivation has.
You don't really have a lot more to do, do you
Just fire that puppy up and go for a cruise in the mountains or something
The sound of a RB, on boost, reverberating off walls should bring your boys back to the yard, if that doesn't stir the loins then all hope is lost.
Might do a track day next month, let's see if it goes bang then lol.
Because nothing breeds motivation more than breaking your car at the track.
For my sake, start slow
Or, go balls to the wall and post video
I has Pssshh for the LOLS
Only opened a bit currently so only minor LOLS, I tried it everywhere from 100% which brought all the bangs to the exhaust and PSSSHHH to the extreme, right down to closed with nil psshh's
Spring is wound down pretty tight, so only really vents at max boostage, under that its very minor dosage
LOLS are pretty good
  • Like 1
Still not broken
Fuel pump, injectors, Flexfuel and clutch
  • Like 3
  • 3 weeks later...
Contemplating a catback or axle back.
Car sounds stock, except for turbo spooling and tyres slipping.
Conundrums:
1. Pre fab - Invidia? N2? R400?Cold start noise?
2. Shop made - pretty much design what I want with the sound I want.
1. Pro: Would be cheap and I get to install, Con: get what I get given sound/drone wise
2. Con: Would be a bit more expensive vs the massed produced item, Pro: able to test what it sounds during the build, Con: I don't really get to install.
2. Found this axle back pic on the nets, will need to speak to my local exhaust shop, Pro: stock rear pipe and resonator, stock exhaust tips, Con: Cost???, not really any other cons that are blinding obvious.
Disclaimer: this is not a performance modification, pipe work can still be the same as now, just need to do something about the mufflers, I'm after just a little more sound.
I keep leaning towards shop built....like the pic
Hmmmmm
29 minutes ago, Dose Pipe Sutututu said:
External gate, I can supply Turbosmart gate
LOL, yeah nah
I had a "screamer" pipe on my 33, for about 3 days, till it got plumbed back in, it sounded like arse.
1 hour ago, Ben C34 said:
Turbos car to make it quieter, Nek minit..
Yeap, I'm a idiot.....
I swear to jebus I'm one of rhe stupidest old hoons on rhe planet.
I blame all the pot I smoked as a teenager.
Becauseconsumer
Plus I haven't been under the car for ages
1x KDT926 Whiteline Front Gearbox - Mount Bushing (BRZ/86) $35.37 $35.37
1x TS-FRS-Rear Torque Solution Rear Shifter Bushing: Toyota 86 $37.36 $37.36
1 hour ago, mlr said:
I'm fairly free this weekend
Go with @PLYNX this wekeend is mental for me :(
Tomorrow cake delivery (missus side hustle), then accountant, then planning out our bathroom reno with the builder, then buy shit, then going to Hans Zimmer symphony (because all Skyline owners are sophisticated LOLOLOL)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
