So I currently have an R32 GTR making 310rwkw's @ 18-20psi (98ron) with a Nistune ECU.
For my next stage of modifications I'm looking to get into the high 300rwkws bracket but was hoping to keep my Nistune.
In speaking to my tuner he's sceptical that it will be up to the task, I understand that a Haltech or Link etc. will do the job better/easier but I would've thought the Nistune would still be up to the task?!?
Current mods and mods to undertake:
  • Garrett -7 turbos (rebuilding to -9 spec)
  • Nistune ECU (hoping to keep)
  • Nismo AFMS (hoping to keep)
  • stock airbox (hoping to keep)
  • 660cc injectors (upgrading to 1250cc)
  • Blitz DSBC (hoping to keep)
  • 98ron (upgrading to E85)
  • stock head gasket (upgrading to metal)
  • stock head studs (upgrading to ARP 2000)
  • stock cooler (upgrading to Plazmaman)
  • stock cams (upgrading to Kelford)
  • stock valve springs (upgrading to BC)
  • Walbro 460 (hoping to keep)
  • Extreme HD clutch (upgrading to Nismo twin plate)
…and yes before anyone chimes in I do realise this could be achieved quite easily with a nice single turbo ;)
The ECU won't be the problem here. The only problem would be whether the AFM's run out of flow.
Given I've literally never read a scenario where someone running -9's has a problem with AFM's running out of flow you will be entirely fine.
The Nistune can do full flex now, as well as run E85 so don't let that one get in the way either if you want to head down that path.
  • Like 1
Exactly what my thought process was going into this......
Cheers!
Yuh.  So long as the pulse width and spark can be controlled, there's no reason to not use Nistune.  By the way, that "so long as" condition is entirely rhetorical.  Of course it can.
The limitations starts to come down to things like the CAS, more than the ECU or even the AFMs.  You can upgrade the AFMs easily enough.  But you can't use a better crank trigger against the Nistune.  It would be good for Matt to make a feature pack that allows the ECU to use simpler and more robust trigger patterns though.
  • Like 3
Makes plenty of sense to me..... ?
Very interested in the outcome as your before / after have similarities with my current setup and what I intend on upgrading to.
Isn't high 300s optimistic for -9s though? I thought that 350ish was typical for -9s.
You haven't mentioned the exhaust setup but I assume that you have a high flowing large diameter zorst?
Hey Rob,
I too thought this initially was probably a little optimistic but I'm basing my build roughly of what ActionDan achieved and from memory he netted around 380rwkws...
Remember this will be E85 and aftermarket cams/valve springs...
My issue is going to be more along the lines of my intake side of things I reckon, I want to retain the standard airbox, intake piping, Nismo AFM's etc... Basically pop the bonnet and it look standard to the untrained eye...
and yes I have a full 3.5" custom exhaust setup...
Edited by mr_rbman
  • Like 1
5 minutes ago, niZmO_Man said:
Nismo AFM = Z32 guts in standard AFM body IIRC
Not quite.  It's supposed to be 65mm body (same as normal RB26) but with flow vs. voltage curve that is same as Z32.  So the internals aren't "the same as" Z32, because that wouldn't work.  But the combo of the small body and the sensor calibration makes them "look like" a Z32 to an ECU.
  • Like 2
Nice zorst!
I had a good look at ActionDan's build and asked a few follow up questions as he had attained some good numbers all right.
I will be looking at similar mods: Kelford Cams, HPI dumps, custom exhaust, bigger injectors, Plazmaman cooler, AC Delco coilpacks etc. But like you, trying to retain the stock engine bay look with factory airbox / snorkel, piping, Nismo AFMs etc.
Will see how it all goes. I have 308KW at the moment which was fine when the original build was done as the drivetrain was ancient but I now have a brand new gearbox / clutch, recoed tailshaft and the diffs are next so happy to have a bit more torque.
I have similar set up as yours and also getting about ~300rwkw on 17psi with 93 AKI (not sure what that is in RON), so I'm interested to see your new results.
I'm confident Nistune won't be an issue for you, and my tuner had done plenty of +400kw Z32s on Nistune with stock Z32 AFMs so I'm sure your other hardware is up to the task as well.
Ah right, I read about them a long time ago, guess time degrades memory.
Also I believe MINE's made basically the same thing.
MINE's made the same thing, but with RB25 AFM internals in stock RB26 65mm housing.
On 7/10/2018 at 7:17 PM, BakemonoRicer said:
Spending all that extra money you are nuts to retain twins.
Those things were in fashion last century
Seriously, go an EFR! Those things are magic and you wont be wasting your money doing things twice!!
Refer to last line of original post.... ;)
surprised it actually took 16 odd posts for it to be mentioned :-P
  • Haha 1
  • 3 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
