So I currently have an R32 GTR making 310rwkw's @ 18-20psi (98ron) with a Nistune ECU.
For my next stage of modifications I'm looking to get into the high 300rwkws bracket but was hoping to keep my Nistune.
In speaking to my tuner he's sceptical that it will be up to the task, I understand that a Haltech or Link etc. will do the job better/easier but I would've thought the Nistune would still be up to the task?!?
Current mods and mods to undertake:
  • Garrett -7 turbos (rebuilding to -9 spec)
  • Nistune ECU (hoping to keep)
  • Nismo AFMS (hoping to keep)
  • stock airbox (hoping to keep)
  • 660cc injectors (upgrading to 1250cc)
  • Blitz DSBC (hoping to keep)
  • 98ron (upgrading to E85)
  • stock head gasket (upgrading to metal)
  • stock head studs (upgrading to ARP 2000)
  • stock cooler (upgrading to Plazmaman)
  • stock cams (upgrading to Kelford)
  • stock valve springs (upgrading to BC)
  • Walbro 460 (hoping to keep)
  • Extreme HD clutch (upgrading to Nismo twin plate)
…and yes before anyone chimes in I do realise this could be achieved quite easily with a nice single turbo ;)
The ECU won't be the problem here. The only problem would be whether the AFM's run out of flow.
Given I've literally never read a scenario where someone running -9's has a problem with AFM's running out of flow you will be entirely fine.
The Nistune can do full flex now, as well as run E85 so don't let that one get in the way either if you want to head down that path.
  • Like 1
Exactly what my thought process was going into this......
Cheers!
Yuh.  So long as the pulse width and spark can be controlled, there's no reason to not use Nistune.  By the way, that "so long as" condition is entirely rhetorical.  Of course it can.
The limitations starts to come down to things like the CAS, more than the ECU or even the AFMs.  You can upgrade the AFMs easily enough.  But you can't use a better crank trigger against the Nistune.  It would be good for Matt to make a feature pack that allows the ECU to use simpler and more robust trigger patterns though.
  • Like 3
Makes plenty of sense to me..... ?
Very interested in the outcome as your before / after have similarities with my current setup and what I intend on upgrading to.
Isn't high 300s optimistic for -9s though? I thought that 350ish was typical for -9s.
You haven't mentioned the exhaust setup but I assume that you have a high flowing large diameter zorst?
Hey Rob,
I too thought this initially was probably a little optimistic but I'm basing my build roughly of what ActionDan achieved and from memory he netted around 380rwkws...
Remember this will be E85 and aftermarket cams/valve springs...
My issue is going to be more along the lines of my intake side of things I reckon, I want to retain the standard airbox, intake piping, Nismo AFM's etc... Basically pop the bonnet and it look standard to the untrained eye...
and yes I have a full 3.5" custom exhaust setup...
Edited by mr_rbman
  • Like 1
5 minutes ago, niZmO_Man said:
Nismo AFM = Z32 guts in standard AFM body IIRC
Not quite.  It's supposed to be 65mm body (same as normal RB26) but with flow vs. voltage curve that is same as Z32.  So the internals aren't "the same as" Z32, because that wouldn't work.  But the combo of the small body and the sensor calibration makes them "look like" a Z32 to an ECU.
  • Like 2
Nice zorst!
I had a good look at ActionDan's build and asked a few follow up questions as he had attained some good numbers all right.
I will be looking at similar mods: Kelford Cams, HPI dumps, custom exhaust, bigger injectors, Plazmaman cooler, AC Delco coilpacks etc. But like you, trying to retain the stock engine bay look with factory airbox / snorkel, piping, Nismo AFMs etc.
Will see how it all goes. I have 308KW at the moment which was fine when the original build was done as the drivetrain was ancient but I now have a brand new gearbox / clutch, recoed tailshaft and the diffs are next so happy to have a bit more torque.
I have similar set up as yours and also getting about ~300rwkw on 17psi with 93 AKI (not sure what that is in RON), so I'm interested to see your new results.
I'm confident Nistune won't be an issue for you, and my tuner had done plenty of +400kw Z32s on Nistune with stock Z32 AFMs so I'm sure your other hardware is up to the task as well.
Ah right, I read about them a long time ago, guess time degrades memory.
Also I believe MINE's made basically the same thing.
MINE's made the same thing, but with RB25 AFM internals in stock RB26 65mm housing.
On 7/10/2018 at 7:17 PM, BakemonoRicer said:
Spending all that extra money you are nuts to retain twins.
Those things were in fashion last century
Seriously, go an EFR! Those things are magic and you wont be wasting your money doing things twice!!
Refer to last line of original post.... ;)
surprised it actually took 16 odd posts for it to be mentioned :-P
  • Haha 1
  • 3 months later...
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
