Hoping to get recommendations and feedback on where people have got their cars tuned. Also feedback on how much it cost would be great.
Tried to look up previous threads, JEM and Jez DVS seem to be common, but those were fairly old threads.
I have a Nissan R34 GTT 1998 Manual, apexi power-fc, hypergear tubro located in Hornsby NSW.
Originally tuned by Trojan in ACT (previous owner), 265kw at wheels, but is running a little rich. Thinking of just getting a full re-tune instead of a fix up.
https://www.sau.com.au/forums/topic/474994-where-to-get-car-tuned/
I wouldn't get a retune to "fix" it running rich. Blow $1200 for no reason to be honest.
Also it may be tuned rich for a reason, generally with thise high flow turbos, the rear housings are small (because they're OEM) and you often have heaps of exhaust back pressure as you can Only get so much air out versus in due to the upgraded compressor wheels.
Now if you were to have a ruler flat instagrammable AFR reading you might find your car will knock or have sky high EGTs due to the low timing. So to combat this, tuners or mechanics turned tuners dump in heaps of fuel to combat knock.
Anyhow if you feel like getting it "re-tuned" I suggest you reset the PowerFC so they at least have to copy and paste another tune on and touch it up.
  • Like 1
1 hour ago, jorgo90 said:
Not so worried about the running rich part in terms of wasted money etc... The only reason why it bothers me is it spits out smoke and gets oil burn/marks on the rear bumper.
Any other solutions or ideas appreciated.
does your car run a cat?
Well in Australia its simple ...compliant catalytic converter legally required so people wanting to lose the cat usually compromise by
1. putting in a free flowing although not necessarily compliant cat or
2. gutting the cat (so hard to tell from the outside)
3. installing a "test pipe" which may or may not resemble a cat.
Or they just lose it altogether...easy to spot by looking under the car.
I would be more interested to know why it is making only 265kw. What model Hypergear have you got and what injectors,  intercooler, exhaust etc?
Generally Hypergear high flows (back then, no experience with his newer high flows) made around the 250-270kW on a roller dyno.
Tao's test rig often read a bit higher as it was always dynoed on a hub dyno.
Hi Guys,
The engine was rebuilt just before I bought it in late 2016, about 10,000KMS ago (Total bill was 15K, i believe that included a new turbo at the time, engine mounts, new suspension and full dyno etc) - previous owner was a stickler for doing things right, and yes I saw the receipts and spoke to the guys that did it.
The car has Hypergear G3 highflow turbo, spitfire coilpacks, SARD 650cc injectors. Z32 AFM, Walbro 255 Fuel Pump. Exhaust brand is unknown and unknown if it is turbo back or cat back, or gutted cat back etc.
The easiest way is to get under the car and check and see re: cats.
Yes, without a cat you know about it. If people following you get headaches in the hills, you have no cat. It is possible to have a really rich tune and have rear bar discoloration etc with a cat, so ideally you'd be checking both the tune and the state of your exhuast.
G3, relatively old design compared to his more recent & modern turbos.
That result is pretty decent!
Jack up your car, unbolt your car, have a look if it's hollowed out or not!
And if you're really keen on getting a re-tune and burning cash take it to Mark @ MRC Dyno in Castle Hill. He would be my pick if I had to choose a tuner. I've seen his timing maps/tunes and compared to others they're much better.
  • 5 years later...
I'd love to do a fix up but a tuner I went to says he doesn't do that, and it's easier just to do it from scratch because if they fix one parameter it could negatively impact another. I was trying to avoid spending $1k+, is this common with tuners?
Yes, here's a scenario.
Say your original tune by Tuner A has been done, with the wrong injector data, wrong sensor scaling, base timing not synced properly. Tuner B then hops on, fixes up the cock ups and now realises the fuel table & timing tables are pretty much invalid.
Easier for them to copy and paste a known working tune from a similar car they've done in the past with similar mods, then tune/calibrate accordingly
  • Like 1
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
