After doing a 5 stud conversion + brake upgrade (r33 gtst brakes) onto my r33 gts I cant get my brake pedal to feel firm.
The car used to have ABS but everything has been removed including the sensors on the calipers. I have compared my brake setup to another non abs r33 and its exactly the same so theres no reason it shouldn't work.
Ive already had a mechanic look at it, tried to bleed it, but still no improvement on the brakes. Besides that I have also tried to bleed the brakes and master cylinder using the brake pedal and a hand pump vacuum bleeder. With the car not running, the first 20% of the brake pedal has play, and the last 80% of the brake pedal feeling solid as.
With the car running, is literally the opposite, 80% of the brake pedal is useless and the last 20% is when the brakes stop the car although i haven't tested it at speed higher than 30km/h.
Theres no leaks, every connection is tight, fresh brake fluid etc. The brake booster is also from a turbo r33 to match the turbo gtst brakes.
Could the master cylinder be broken? is there a way to test if it is? the brake booster and master cylinder both worked before installing them.
I read on a forum from someone who did the same brake upgrade, same car, and had to upgrade to brake booster and master cylinder cause the brake pedal always felt soft/spongy. But there was no information on the upgrades he made?
Any help would be appreciated!
Tbh I was told this is a normal and that stock brakes are crappy??? As you said, there's no feel at the start and all of a sudden everything happens in last bit. Mines a non turbo with 5 stud conversion also.
A few people recommended getting a brake stopper which I'm considering trying and plus they're quite cheap. It fits in the engine bay and say it stops the flex in the firewall when braking. Makes the brakes feel stronger (more bite) and has better feel in pedal.
Edited by ossy
My last 33 brakes felt a lot more firmer tho but that was with stock non turbo brakes, I just can’t understand that upgrading to gtst brakes would leave my pedal feeling so soft? Surely it can’t be normal? Having brakes that don’t work until the last 20% just doesn’t feel safe or reliable aha.
And yea the master cylinder brace I seen that the other day they’re only like $50. But like you said it will only help with stopping the fire wall from Flexing. It won’t improve the 80% of the pedal that doesn’t do anything :(
The gtst master looks pretty identical to the gts master. But I couldn’t use it because it only uses two brakes lines, and I need three.
No experience with brakes so I’m not too sure what you mean, although I read something saying that since the gtst brakes are bigger it requires more brake fluid to work resulting in a softer pedal. If that’s what you mean by the calipers piston area difference? I thought brakes just relied on pressure which means having bigger brakes really shouldnt affect it But I’m not really sure so yeah..
Bore size is like gearing. Small bore means more pedal travel with less resistance. A bigger bore will mean less travel but harder pedal. The biggest stocker is the GTR BM57 but something close to that will help. Also steel braided brake lines will help.
Here’s a another lesson for the day, you won’t learn anything if you don’t try :) I ain’t gonna apologise for giving something a go. Like I said, I even got a mechanic (someone who knows what they’re doing) to try and sort it out. So chill bro
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
