Hi SAU, happy NY to you all.
I'm looking into a power upgrade for my 32gtr, educating myself on options. I've done a fair bit of reading on SAU and elsewhere, and now I'm hoping to get some advice about turbo selection from experienced folk here.
Currently running:
Mild 2.6L with forged pistons and rods, fresh mild ported head, oem cams, adj. cam gears, JUN oil pump, extended sump, oem cold side, N1 turbos. With supporting mods this is good for a modest 281kw at the wheels on 98.
Goal:
380-400kw at the wheels, with a nice wide torque band and response that is no worse than current, and preferably better. This is a regularly driven street car that will see the odd squirt here and there, cheeky track days etc.
Some considerations:
I think I'd rather go EWG and get the manifold + wg + bov stuff done, in preparation for an engine refresh inc stroker upgrade in future.
Some of the thoughts/suggestions so far:
EFR7670 ewg 1.05 - highly responsive but limited to around 350-360kw on 2.6Ls?
EFR8374 ewg 1.05 - good power but better suited to 2.8L?
GTX3576R GEN II 1.06
Thanks in advance!
Edited by shodan
Currently running:
Goal:
GTX3576R GEN II
Thanks in advance!
Go with the 8374. You will NOT be disappointed
Not likely a 7670 would be limited to 350 or 360.
My stock donk Evo 9 makes 325kw with 500nm by 4000rpm with 24psi. A well setup 7670 should blow around 420kw "all in" give or take.
Id say 8374 if you were prepared to go V cam. But i personally think itd be a bees dick too big for a nice street setup.
Though in saying that itd still be on around the same time if not sooner than a set of 9s or 7s ?
This part might explain the power targets: Mild 2.6L with forged pistons and rods.... on 98
If 98 is a restriction than that kind of power with "no worse than current" response is impossible.
That said, something 8374 sized is going to be a minimum requirement if 98 is a must have. With an 8k rev limit the 8374 is going to be my vote too. I had a 7670 on a 2.8 and it was nosing over up top at about 6800rpm.
This was OK for me as mine was a RB25 based 2.8, not a RB26 based motor.
This may or may not be perfect if you prefer revving to 7500 instead of 8500 depending on the kind of RB26 owner you are ?
To be on the safe side of everything I would be thinking something 8374 sized is likely the best compromise of running things with safe overheads.
Ahhh Fuark what a dope...  Missed that bit! ?
Well then if 98 definately 8374 1.05 ?
Yeah sorry, didn't really make it clear I'm not running E85- fuel system upgrade is another phase for the future.
My N1s would be similar to 7s I guess, so I could live with similar performance. From the EFR threads I read several positive comments re pre-spool transient response
Edited by shodan
Thanks for pointing that out Lithium. I averaged that figure from anecdotal comments, from the EFR threads here and elsewhere. Can I ask about your experience or knowledge of cars with either 7670s or 8374s on stock capacity RBs? , you seem to be fairly involved with car dev in NZ
I'm not at all surprised at your response
Yeah 98 for now. E85 sometime in the future.. Good advice thanks mate. I did read your EFR thread comments about the 7670
3 hours ago, burn4005 said:
8374 because eventually you'll want e85 and 480kw+
I had 400kw, got over it and now I have 500kw. I like 500 better.
Haha I'm sure that's exactly how it goes. I have been considering it for sure. Just wondering if I'm better off with the 7670 for a boost in response now, (and live with reduced total power) then moving to an 8374 when i eventually go 2.8.
  • Like 1
6 hours ago, shodan said:
Where do these fit in the Garrett pecking order? Better than GTX? different?
Brand new release for 2019 and improved over GTX range i believe.
Although have not seen any real world data just yet.
I'm telling you...the 8374 will CRUSH your N1s on boost threshold, response, overall power, midrange torque etc...yes on even a stock 2.6
I have a car with new -7, fresh motor, camgears, haltech. Then I just installed a .92 8374 efr on a stock 2.6 car. No kidding the efr absolutely destroyed them both as a better operating engine. I think it's pointless to go with anything smaller to be honest because you really don't spool any faster...only reduce topend.
  • Like 1
On 1/9/2019 at 7:47 AM, Kinkstaah said:
This may or may not be perfect if you prefer revving to 7500 instead of 85009500 depending on the kind of RB26 owner you are ?
Fixed that for you
Mate of mine is doing a 26 7670 build should be running in the next few months, will be interesting seeing how it goes compared to my 8374. Can't say i'm 100% convinced its the better option for pure street duties, though wouldn't go a 7670 for the track etc.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
