6 hours ago, r32-25t said:
Ask the finance company for a pay out figure and they will tell you the exact number
Correct....... Unless you have the correct software calculators it's near impossible to get close to an accurate figure.
The initial amount borrowed, the term, the interest rate, duration of the loan, whether there is a residual amount (if commercial lease) all play a part in the final payout figure.
Some institutions may have a payout calculator on their websites but realistically, as the previous poster said, just ring them.
Make sure you have all you loan information in front of you when you do for ID purposes.
Cheers,
Bob.
Thanks guys, I worked out my own payout. This was my method . My Loan was over 84 months, I had paid 44 months which left 40 months. I then multiplied 40 x the monthly payment and came to an amount. Then calculated the monthly amount of interest and multiplied it by 40 giving an amount of interest which would be deducted from the total amount of monthly payments left as above. Without allowing for an early payout amount. My payout figure was $4,593.21 less than what the finance company gave me. So be very careful if you try to estimate it yourself. This is the reason why I wanted to know the formula. Cheers Richtind.
2 minutes ago, Leroy Peterson said:
5 minutes ago, GTofuS-T said:
not if you know what you're doing... or know how to use google...
Then it's not DIY, it's using a tool. But even then, I'd bet money it's still not spot-on.
I didn't realise DIY meant eyes closed take a swing at something without learning how to first... i guess all the work i do on my car can be deemed professional then :4_joy:
the only scenario where you can never be accurate is in a variable rate situation, but car loans are usually a fixed rate. Anything else should be easy with all the info from the agreement in your hands.
Well that's what OP did and what I was referring to
The ONLY accurate way to do it is get a current payout quote from the financier.  Every institution has different early termination fees that they add on based on how far into the loan you are.  Generally it's a percentage of what they're losing by you not completing the full term of the loan.
Back in the day, when I was taking car loans, the finance companies used the "Rule of 78" - google it. Basically it defined that the bulk of the interest was paid early in the loan - so if you paid off a 4 year loan in 2 years, you paid almost all of the interest you would have paid if it stayed over 4 years. It was a fairly expensive learning experience for a youngster on apprentice wages, who liked to change cars regularly.
I have no idea if it's still used, but I suspect it's probably not legal these days (probably wasn't legal in the 70's either, but laws weren't so important then).
You are 100% correct........ It has been outlawed for consumer loans but is still in effect for business or commercial leases etc.
Who cares
Obvious scam/ bot post
Has made 2 posts both in this thread saying hey look what I managed to achieve
Who comes to a forum to ask how to pay out a loan. U ring your bank/ financier
If u calculate a lower amount they couldn’t give 2 shits.
Until you pay what they say you owe it will remain their property unless you can provide concrete evidence it’s too much
  • Like 1
Only way to do it is call the financier.  I work in asset finance.  I can guarantee it's the only way cause every lender is different.
  • 1 year later...
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
