So, in summary, there is a fair bit more work before this will run OK. Whoever gave you the idea that you could bolt on the turbo, injectors and ECU and it would run skipped a few steps.
1. One way or another you need to match the ECU wiring to the ECU.  You need the pin outs for both ECUs (old and new) and compare every difference. You either need to cut and rejoin your current loom at the ECU to match the new pins, or you need the ECU loom that matches your ECU, and then change a few of it's connections at the other end where they are different (and they will be). You may need help from someone who has done this before if that doesn't make sense
2. There are at least a few mechanical/electrical differences to deal with. I'm not familiar with this particular swap but the guys mentioned the boost sensor, I would expect there is also a difference with fuel pressure regulator needing to be a turbo version and have a boost input, some sort of boost controller, fuel pump is probably different, air flow meter might be different as well?
3. The ECU you have may still not run the DE engine well due to differences in cam, VCT and compression. You will probably need a nistune at a minimum to get in running well. Since it is a manual ECU it won't talk to the auto; it will work but it won't give smooth shifts because the trans can't tell the engine it is changing gears and to reduce power (timing) momentarily
There is still a big job ahead to get it running properly, you've gone down a difficult path. Realistically you need to find some other way to get to work for a few weeks...
R34 NA RB25s have a separate TCU in the car for the auto. On the turbos, the TCU is a board inside the ECU. The only real question is whether the turbo manual ECU will talk nice on the system bus to the TCU. I would expect that it probably would not. The reason is that the turbo auto ECU talks to the TCU internally (whispering in its own ear). The turbo manual ECU does not expect to have to talk to any TCU, so probably doesn't send or receive ANY auto trans related messages. That might leave your auto's TCU struggling to work out what's going on.
I predict bad things because of that.
And it's not as if you can get an auto image dropped into a Nistuned manual ECU either. You can, there's nothing stopping you, but I would not expect it to talk to the external TCU, because it would be just talking inside the ECU - whispering in an ear with an earplug in it (or an ear that looks a lot like Van Gogh's.)
The reverse situation is easy. I have an auto R34 ECU (with TCU inside) running the engine with a manual gearbox. That works because I am the TCU.
Nistune in the new ECU will resolve my point 3 above, but it won't correct any physical wiring differences. On the other hand, if you can nistune your original ECU than both 1 and 3 are covered off.
With due respect, this is simply wrong. My experience from this conversion, the trans went into limp mode and was stuck in third all other gears except reverse were unavailable.
  • Like 1
This was good advice, I PM'ed the young fella the complete R34 workshop manual and gave him the same advice, he PM'ed me back that he had no idea what he was looking for. So I PM'ed him all the pin numbers he should look at, but the eureka lights still did not come on!
Perhaps he could get some advice from Nistune on whether his original N/A ECU could be tuned, the VCT timing exists and could be changed, the boost control could be added using the variable inlet pinout. But would have to figure out fuel pump output for turbo. Obviously the ECU would need to be JECS and not Hitachi
Edited by Rusty Nuts
  • Like 1
Fair enough and thanks for saying. My experience is with Stagea W34 not Skyline R34. They run fine with manual computers and auto trans but it sounds like there are differences in later model/R34.
Also, this suggests the Stagea ECU he has will not do the job with the later R34 auto trans for the same reason.
  • Like 1
I have PM'ed him to find out whether his old N/A ECU was a JECS then advised him to talk to Nistune as to possibilities.
It IS possible to use an GTT ECU's 'TCM' I.e the inbuilt pins on the ECU)
to drive the n/a gearbox. Yes you can just bypass the n/a TCM and wire it to the GTT ECU.
The inputs of the n/a TCM DO translate to the extra pins of the R34 GTT auto ECU.
If you have a manual engine ECU tho then GL to you. Aftermarket auto ECU's do exist and DO work, but its utterly dumb when 'use anything other than the n/a auto gearbox' is by FAR the best solution.
I think that's the point though, as in he's trying to avoid rewiring the auto tcu module directly to an auto turbo ecu directly.
I think that is what is going to have to be done in this situation though as you've pointed out.
I say this here because to his credit he did search and found I encountered the same issue and solved it back in the day.
I found that out by reverse engineering how my aftermarket transmission ECU had been setup and working. But really, the NA gearbox is a piece of garbage, and the GTT one while stronger when built (Mine is still going strong in the UK where I sold it....) pales in comparison. The answer is manual. And if you can't drive manual, have fun learning because it is fun and jesus the car is better manual than it ever was auto. The skyline gearboxes are not exactly lovely DCT's.
But yes in theory it can be done....  but in reality, ANY time or money spent working it out should be deferred to putting a manual gearbox in.
  • 1 month later...
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
