I support this from the firewall forward.
Actually I lie, there's a guy with a still streetable SS doing pretty respectable times at Winton, so as much as people on SAU bitch about Commos' being unable to handle, it clearly can be done to a pretty decent extent. Realise this is an auto so you won't be doing that... but still.
https://www.carsales.com.au/cars/details/holden-commodore-2005/sse-ad-6431803/
Smaller cams are better choices if you want the thing to be good at what it does best (i.e be a comfy cruiser around town), cam surge will ruin everything.
  • Thanks 1
Just did oil and filter change.
Pulled dipstick and noticed it was a little cracked, so....I wobbled it and it broke.
Dip stick is now about 1.5 inches to short.
Fill with filter is 5 litres, so I just dumped the whole 5 litres of Castrol Edge 0w 40 into its belly.
New dipstick is incoming, thanks to Ebay.
41 minutes ago, mlr said:
Bring on the broken stuff...
I have the full Holden service info pdf set, it is massive. When iam able to operate a computer correctly I will pm a Dropbox link to you. Few beers in so could get bad athe moment
  • Thanks 1
Just ordered new Ultima struts and FE2 height king springs $600 delivered (I pulled a wheel and the shocks looked like the originals from 2002, the FE2 springs will give me an additional 10-15mm height, helpful when doing Dukes of Hazards jumps), and some $20 spring compressors (again, I cannot find my old set, meh, $20, ppfftt) off Ebay to swap out the strut tops.
But tomorrow is coolant flush then full external clean, wash under the car as well as the paint, then polish, glaze then wax.
I'll also give some of the fixtures a squirt with penetrant in preparation for undoing suspension nuts and bolts, hopefully next weekend.
Psycotherapy and a bit of a work out.
… could I also get this? The VZ one is a fkin DVD and near impossible to find. I have the VY Series 1 one, but they... change stuff.
Mark if you want to be a real bogan now that you have a Commo you will have to install the mandatory bow tie badges.
My daughter who is not a car enthusiast always says "bow tie badges on a Commo would make baby Jesus cry" whenever she sees a Commo with them.
Go on you know that you want to.
LOL, Chevy badges on Holdens causes the AIDS.
In other news
Coolant flushed
Car is all clean and shiny
Decided to do the spark plugs.....but.....the first lead I pulled fell to bits
$130 later I now have
For
Jobs for tomorrow
Plugs and...leads
Trouble shoot inactive cruise control. i.e. "look at the fuse"
Pull door trim and see why the front inside passenger door handle doesn't work, well I know why it doesn't work, the handle is good but it seems to be missing a spring or something????, I'll most likely pull the trim off the drivers front as well to see what it is meant to look like.
Plugs and leads are done.
Also replaced the OEM heat shielding (masonite with tinfoil glued on) with real heat sheilding, held in position by 2 x OEM clips and 1 x cable tie (LOL, cable ties already)
Door was a cheap fix, just needed to reconnect the clip.
Getting to the clip on the other hand was a PITA, lots of jamming the phone inside and taking pics, then jamming my hand in and blindly fumbling around until the blue clip was reattached to the rod.
I want more sidewall.
I going "full bogan spec"
17 x 9 chasers with black caps.
I'll get some Hankook RS-4 255/40 17, should give me 20mm more sidewall.
Slight diameter change, 24.8 diameter, as opposed to the OEM 235/45 17 which are 25.1.
Should be 100kph on speedo and 99 on, ummm, the radar gun.
Will sell the 19" Simmons once the car is "full bogan spec".
  • Like 1
  • Haha 1
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
