I support this from the firewall forward.
Actually I lie, there's a guy with a still streetable SS doing pretty respectable times at Winton, so as much as people on SAU bitch about Commos' being unable to handle, it clearly can be done to a pretty decent extent. Realise this is an auto so you won't be doing that... but still.
https://www.carsales.com.au/cars/details/holden-commodore-2005/sse-ad-6431803/
Smaller cams are better choices if you want the thing to be good at what it does best (i.e be a comfy cruiser around town), cam surge will ruin everything.
  • Thanks 1
Just did oil and filter change.
Pulled dipstick and noticed it was a little cracked, so....I wobbled it and it broke.
Dip stick is now about 1.5 inches to short.
Fill with filter is 5 litres, so I just dumped the whole 5 litres of Castrol Edge 0w 40 into its belly.
New dipstick is incoming, thanks to Ebay.
41 minutes ago, mlr said:
Bring on the broken stuff...
I have the full Holden service info pdf set, it is massive. When iam able to operate a computer correctly I will pm a Dropbox link to you. Few beers in so could get bad athe moment
  • Thanks 1
Just ordered new Ultima struts and FE2 height king springs $600 delivered (I pulled a wheel and the shocks looked like the originals from 2002, the FE2 springs will give me an additional 10-15mm height, helpful when doing Dukes of Hazards jumps), and some $20 spring compressors (again, I cannot find my old set, meh, $20, ppfftt) off Ebay to swap out the strut tops.
But tomorrow is coolant flush then full external clean, wash under the car as well as the paint, then polish, glaze then wax.
I'll also give some of the fixtures a squirt with penetrant in preparation for undoing suspension nuts and bolts, hopefully next weekend.
Psycotherapy and a bit of a work out.
… could I also get this? The VZ one is a fkin DVD and near impossible to find. I have the VY Series 1 one, but they... change stuff.
Mark if you want to be a real bogan now that you have a Commo you will have to install the mandatory bow tie badges.
My daughter who is not a car enthusiast always says "bow tie badges on a Commo would make baby Jesus cry" whenever she sees a Commo with them.
Go on you know that you want to.
LOL, Chevy badges on Holdens causes the AIDS.
In other news
Coolant flushed
Car is all clean and shiny
Decided to do the spark plugs.....but.....the first lead I pulled fell to bits
$130 later I now have
For
Jobs for tomorrow
Plugs and...leads
Trouble shoot inactive cruise control. i.e. "look at the fuse"
Pull door trim and see why the front inside passenger door handle doesn't work, well I know why it doesn't work, the handle is good but it seems to be missing a spring or something????, I'll most likely pull the trim off the drivers front as well to see what it is meant to look like.
Plugs and leads are done.
Also replaced the OEM heat shielding (masonite with tinfoil glued on) with real heat sheilding, held in position by 2 x OEM clips and 1 x cable tie (LOL, cable ties already)
Door was a cheap fix, just needed to reconnect the clip.
Getting to the clip on the other hand was a PITA, lots of jamming the phone inside and taking pics, then jamming my hand in and blindly fumbling around until the blue clip was reattached to the rod.
I want more sidewall.
I going "full bogan spec"
17 x 9 chasers with black caps.
I'll get some Hankook RS-4 255/40 17, should give me 20mm more sidewall.
Slight diameter change, 24.8 diameter, as opposed to the OEM 235/45 17 which are 25.1.
Should be 100kph on speedo and 99 on, ummm, the radar gun.
Will sell the 19" Simmons once the car is "full bogan spec".
  • Like 1
  • Haha 1
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
