@PranKif I have not misunderstood you mean the type of engine?  it is an bmw n47 150cv cammon rail.  mounted cp3 r90 pump and cpc 8 hole injectors.  and then the usual things: exhaust, intercooler, filter, camshaft with higher profile etc.
Edited by darrix
1 hour ago, darrix said:
@Predator1I don't want to do any engine conversion.  I want my engine.  I'm interested in doing 2.8 bar.  then I will see the spool later
It was a joke. This is a Skyline forum. We know nothing about BMW 4 cyl diesels and how their compound turbo systems work. So we recommend suitable Skyline related suggestions.
I see, okay, so I think the best option then is to directly run a -12 fuel line and inject it straight in the turbine housing. We usually do that on very high powered Skylines... better known as an afterburner.
I used to drive a Ford econovan, which I ended up welding the diff then putting in a v6 from a VN commodore.
When it was was a carby 4 cyl that did the best key bangers and could keep on driving at full throttle up a hill with ignition off. Good times. Funnily enough it also blew a head gasket. No forum posts involved  just fixed it and continued to ping its tits off. I miss that heap of shit
So yeah I know how diesels are cool
Hey mate, pull your head in. You come onto this site, talk utter incoherent garbage, and then call someone an asshole. Good work, you'll get your answers doing that.
It is clear that english is not your first language and are having trouble getting your point across, as nothing in the way you say things makes any sense to any of us.
If we know what you're on about sure, people will try to help you, but I suggest SAU is not the place to be asking about compound turbo diesel modifications on a BMW.
  • Like 1
4 minutes ago, darrix said:
because of the forum.  I thought it was a general forum and you could talk about everything
You absolutely can talk about everything. I have 2 BMW's myself. But it doesn't mean people here will know what you want to learn.
  • Like 1
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
