Nothing "wrong" with it if you require it for your purpose, like actual motorsport. The original point was about billet blocks being like sequentials following the "image of cool" nowdays. Nice to have, but hardly necessary for non motorsport street cars.
Which is back to the original question of why the OP feels he requires a billet over cast block.
Now that we've derailed this thread about billet blocks, does anyone know if the PPG or stock ratios are better for the stock 5 speed in the R32/R33 GTRs? I'm looking for a synchro transmission and I don't think I can afford the expense of doing a V160 swap properly.
8 hours ago, BK said:
I know billet blocks are good for rigidity when making massive power, but I was asking specifically the OP why he feels he needs / wants a billet block. Does he want 2000hp or just bragging rights ? Plenty of big power RBs not using them and new RB26 blocks are pretty affordable.
Hi there, I've been using the current engine for 5 years now. It's running fine and doesn't give me any trouble. I use it as a DD as well as tracking it 5-6 times a year. It's running E20 and is making 700hp on twin 6258 EFRs. The HKS 2.8 kit hasn't give me any problem and currently it is running fine. I feel time is approaching for a replacement block so why not go for a bit of an upgrade. While the limitation of the HP is not the block right now, it is the fuel I use, beside I don't need anymore HP, it is plenty fast, but I want the same reliability and maybe a bit more boost doesn't hurt :-).  The current RB engine are quite expensive now so I don't mind spending a bit more to get a lighter and stronger engine but if it comes with compromising the reliability or heat issue I'm not going to buy it and so far I haven't really got a straight answer from the shops so I'm asking the owner/s who had bought one if my concern is ligitimate or not.
Thanks
Tobey
Let me explain a bit more of the weather condition in my country. It gets to 40+ Celsius for 1-2 months a year and I get stuck in traffic sometimes 30 minutes to one hour.  There are many cars on the road and you can't really drive to dissipate heat like in the VDO above. It's also quite humid.
I heard in the VDO at 2:55 that the engine runs at 83 degree. Let's say the temperature in NSW on the day of filming is around 25C, seeing they open the window it might be cooler, but if your add 10 degrees to that, with the condition coolant will be at 93 degree. For me, for a car running around with wind blowing that temperature is pretty high. I haven't considered the fact that the hotter the temperature the harder it is to dissipate heat and I haven't even added traffic and heat of other cars to the equation because when in traffic that is when it heats up very fast.
I guess I found my answer but to be fair it does also depends on how the ventilation of the car is set up.
I'm not here to bash the billet block. I genuinely want one but I have to play a role of skeptic here.
The question is really more why do you want a billet block? They're designed for 1200+ hp builds. The liners are extremely thick and the water jacket doesn't do as much as it does in the stock block which is a closed deck that reduces coolant flow.
You should really consider what this car is going to be used for. If it's going to be idling in traffic all day that means keep the power relatively low to reduce cooling load on the engine, keep the OEM water pump, big radiator, stock clutch fan with fan shroud, proper radiator ducting. All of those requirements point towards either OEM or N1 block. It would be cool to have some billet aluminum block tailored for say 600 whp max as a "street oriented" block but the people willing to put down 10-13k USD on a billet block usually want big power, not just removing ~30 kg from the front of the car.
Thanks for the response. I do half track half street driving on this car. For street you can't really avoid congestions in the heart of Bangkok. As for cooling, I still have the clutch fan, an oil cooler with a small fan, HPI 3 way radiator with the biggest cfm fan out there, as well as an extra small coolant cooler with fan. The airflow has also be designed to get ride of the heat while driving. The car is cool right now. I figure I can take on a bit more heat while removing the weight off the car as there is nothing else that I can do to improve the car within the limit that I want it to be. The weight should improve the handling of the car some what but I'm not willing to sacrifice the reliability issue for it.
You are right that people are not willing to put down that much money for just weight reduction, as a replacement to a stock streetable block. As the stock block continue to go up in value, if these shop advertize that billet block is replaceable to the stock block it should have better cooling than the stock block and have other better design features, which when I asked they refused to do it.
umm, no they are not going up in value. Brand new RB26 05U blocks are about $3500AU. They've been about that since as long as I can remember. That's a big difference in price to a Bullet billet RB26 block at around $14000AU (Not $13kUSD - don't know where that came from).
Yeah huge cost and for what - why not just use a PRP Block brace and machine a new block?
i feel for your street car with odd track day you will keep block twist to a minimum and save a tone of cash in the process and could still throw a few extra PSI at it.
On 02/12/2020 at 9:35 AM, Kinkstaah said:
Do not underestimate the hardpark instagram peer pressure. It is very real.
Fully this. Technology/development has come such a long way in the last few years. Making '1000hp' is much easier than it used to be. Fact is people expect a lot from built engines and they are pushed to the limit. Guess what, they break. They all do. After you have sunk 30k, 40k, 50k (and the rest) and you have a failure, it all becomes very hush hush. People only see the timeslip and ridiculous MPH and think wow. what a street car, when in fact they have lunched multiple engines to get there or have spent another fortune chasing that tenth.
Any of these high powered cars are very much not street cars despite what people portray on so social media. Driving it to work once then doing highway pulls on the odd saturday night does not make it a street car. It's a race car with rego plates. If a highway patrol pulled you over, youd be f**ked.
Get a billet block, fill it with expensive gear and send 70psi through it. Please tell us how it goes.
  • Like 4
Why do Australians love to talk in HP when for everything else we use the metric system?
Remember when NASA lost a spaceship because some fk tards at Lockheed Martin decided to send calculations in imperial shit?
Space vacuum = 0 kPA
Earth = 100 kPA
Sick RB = 400kPA
It's like when American morons tell you water boils at 212 degrees, just sound so stupid, water freezes at 0 degrees C and boils at 100 degrees C - so logical.
HP is like measuring your dick from your arsehole.
  • Like 1
  • Haha 3
Horsies are more powerful than killer wasps naturally!
Old mate should go for an investment cast block as per proper practice, ha. There's that many donkeys with cnc mills turning out engines with superfluous casting features carried over and a few with poor alignments, I would be hesitant to lay hard currency down.
A pet hate is the use of billet in the automotive world, but that's a losing battle, might as well call it, dumb cee you next Tuesday, aerospace grade.☺️
Edited by 2pee
  • Like 1
Now that is GOLD Johnny !
Ive just laughed so hard I wizzed myself !
Are you gonna yell at me if I mention the Europeans use PS as a measurement of engine power as well ? ? ?
But seriously for the amount of cash that you would throw out there Id rather try and pull weight out of the car and look at carbon fiber doors, super light weight wheels and light weight seats to save 30-40 kgs and end up with change !
  • Haha 1
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
