42 minutes ago, Old man 32 GTR said:
Yeah I hear you, this is my car now, even with the 68/70, it’s on when you roll the throttle, rpm doesn’t really matter. As a street car, it’s probably as good as you’d want, but because I’m a little weird I think ‘As a GTR’ where do I want it?
shouldnt a GTR have lag, isn’t that part of the driving experience, lol
If I do this, it won’t be one engine out and one in, it will be engine bay respray, blast and coat subframe, replace bonnet, re wire engine bay. I will bring the bay up to a standard I want it. It presents well now, but It’s no where near finished to a level I’m happy with.
But thanks for the the input, I appreciate peoples opinions on this, helps to give perspective and give me an idea what to expect if I move forward with this.
This is my plan now that my engine needs to come out
31 minutes ago, WantGTR said:
26 block here. if i had my time again id go 30. you live and you learn.
Hi bro, how you been? How’s the car?
I might have an rb 30 for sale soon! Lol
23 minutes ago, Stixbnr32 said:
Its something that was in my mind when i built my car.   GTR's meant to be twin turbo and 2.6L.
And have HICAS and ITB’s etc, for me it’s a juggling match, I want to build the car and retain as many ‘factory’ features as I can, but I want 500kw so there will obviously need to be some sacrifices made.
Off topic, but another area of the car that’s  got my head spinning is brakes, mine is currently fitted with V-spec brembo’s. I like this as they were a factory fitted item, but I’m so tempted to put the new Alpha Amega brembo kit that someone posted here.
Interior, I have recaros fitted currently but have purchased genuine R32 seats, the interior will be getting a full makeover and I’ll be going back to factory colours but use more modern/ better quality materials.
I think I can relate. I'm in the same boat. My original plan was 2.8, but here we are. I had to ditch the clutch booster to make my GReddy plenum fit :(. The only 'stock' feature I've ditched is HICAS, still keeping AC/ABS etc.
Re Brakes - Look up BrakesDirect - They did me an AWESOME deal for a pretty dam good price. 6pot fronts and 4pot rears.. 378mm fronts and 355mm rears. They brakes are fkn HUGE.
If i had my time over again (was 7 years ago) and i was 29 and naïve i would have gone single turbo and 2.8L at least.
Is 2.8L stroker on the RB26 really a wise move to go for in a rebuild? I get the impression that the RB26 was already a stroker motor from the factory and was originally intended to be a 2.4L. 2.8L would cause the conrod/stroke ratio to get even more unfavorable.
I'm currently planning out an RB26 build and this issue has made me go back and forth on whether a stroker kit is really wise.
Depend on what stroker kit you use
Stroker kits are either 119.5mm or 121.5mm, but the stroke in both cases increase to 77.7mm. So you're picking between a 1.56 rod ratio or 1.54 rod ratio. Either way it's on par with the B18 used in the Integra Type R, which seems to be pretty close to the edge of what is considered safe. The longer conrod length kits use a different piston design to get everything to work. Anyways, my plan has always been to target low power and focus on balance. I expect with the HKS GT3-SS turbos I selected it will already nose over well before 7000 RPM even with 2.6L displacement.
Edited by joshuaho96
You come up with some weird shit. Of course stroker kits are a wise choice. Are you saying a square bore / stroke like say 86 x 86mm would be even more unfavorable ? I think we know what the real world answer is here as quite a few good performing engines are exactly this.
For the record, I too went the RB26 block in the 121.5mm rod length Nitto 2.8
Yes, if you're going to go past a 2.8L stroker on an RB26 block it definitely makes sense to go to an RB30 bottom end instead, which has a much longer 152.7mm conrod. Even with a 3.4L, 94mm stroker kit on an RB30 you're still at 1.62 rod ratio which is roughly what the RB26 is at stock.
More cubes is better for performance no doubt, my concern is that going to a 2.8L stroker on the RB26 means you might increase piston side pressure to unfavorable levels, and that going to a 121.5mm rod means you compromise the piston design. Shorter compression height means there's less room for the piston rings, either the top ring gets closer to the crown, the oil control rings get closer to the piston pin bore, or the rings have less spacing.
Personally, I'm really hoping the turbo I selected is small enough to not require agonizing over this issue any further.
The rings are definitely thinner on the Nitto 2.8, with top ring at 1.0mm and second ring at 1.2mm with the custom JE pistons. For comparison, most other RB pistons like CP use 1.2mm top and second 1.5mm rings.
For your situation, the turbos your going to run don't really need a stroker. But would it be better with bigger than 2.6 capacity with them ? Yes, absolutely it would.
I was under the impression that if a turbo is already choking the engine above a certain RPM, additional displacement would just shift the power curve down some amount of RPM. Is this not the case?
Alcons?
Have you driven a decent 2.8/stroker RB? Building a 2.6 is a waste of time. Less text book, more get in and drive it.
Having had a Tomei 2.8 in my car for 15 years, if someone said that I HAD to run a 2.6, I would sell the car. They couldn’t pull a skin off a custard. It’s made out like the rings are worn in 2,000 kms and it needs a rebuild. Realistically, it would have spun a bearing or the car would have been sold on by the time it needs to be “serviced”, especially with turd twins which you won’t be revving north of 8000 rpm with.
There are positives AND negatives for every RS ratio.
  • Haha 1
2 minutes ago, Piggaz said:
Have you driven a decent 2.8? Building a 2.6 is a waste of time. Less text book, more get in and drive it.
No, but I'd rather not spend 5000 USD on a stroker kit only to discover that the engine peaks in power undesirably early. -5s are too small for 2.6L, but the GT3-SS is so small that it has trouble holding boost out to 7000 RPM even with 2.6L. I have a feeling that if you stroke it out to 2.8L it's going to be even worse in that regard.
-5’s are too BIG for a 2.6. My god they’re a heap of shit to drive on a 2.6. Again, have you driven that setup? You’d be pumped to the moon and back by a euro hatchback.
I wouldn’t piss on those new journal bearing shitheaps from HKS. Waste of time.
You may be only looking at where they “fall off”... but how they drive and how the come on is chalk and cheese.
The GTR is a big, heavy heap of shit with tall gearing with the 5 speed and can’t be helped by any “smarts” in the engine bay (like VCT). It’s a small stroke, low comp donk with a dumb head. It needs all the help it can get to push around that pork!
It’s ok, I own one, have had for 15 years. But to own one with a 2.6 is a no go for the above reasons.
  • Like 5
So what about 2.7?
I know of car that’s a 2.8 with a 6870 with a 1.15ts rear on it and he’s claiming he’s all in at 4,100. So Even with the smaller engine it’s sounds like it’s not going to be a pig but you won’t be riding the wave or torque you are able to currently
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
