Heya folks,
Just got home from a drive and my turbos decided to shit themselves.
I actually had it up on the market but now it looks like that's being put on hold till the issue is fixed. :(
The car is in amazing condition and I don't want to do any big single upgrades or anything like that. Since I'm pulling them out may as well put something a little better in there.
Any recommendations on some decent twins that aren't going to break the bank?
I don't want to have to change the manifold or anything like that so it would have to be something that bolts straight in.
Thanks in advance!
https://www.sau.com.au/forums/topic/483574-twin-turbo-upgrade-r33-gtr/
On 20/04/2022 at 3:11 PM, robbo_rb180 said:
Either rebuild what you have by @hypergear, find a second hand set or 2860-9 upgrade.
Exactly. 2nd is quicker to do and might cost a little more, and you will get 20% more whoosh.
You'd be mad to convert a GTR from twins to single these days unless it is for genuine race only use
https://gcg.com.au/turbo-charger-kit-nissan-rb26-low-mount-iwg-gt2860r-9-xtr000908i.html?ref_cat_id=Turbo-Upgrades-Kits-Petrol-Turbocharger-Kits
This what you boys mean by the -9s?
Also, while we're here - since they're blown and the car is sounding like a hilux, does this mean I shouldn't be turning it on at all and tow, or is it ok to not hit boost and drive it to the workshop?
Edited by Mlads33
I wouldn't allow the engine to turn until you've verified that you haven't gotten a bunch of ceramic bits from the turbine going backwards from exhaust gas reversion. Letting off at high rpm you can see the manifold pressure reach high levels of vacuum.
Edited by joshuaho96
Yes, those. That kit includes the slightly different oil drain fitting you need.
And no, don't run or drive it. Depending what has happened exactly there could be crap all through your oil. Also, it is worth having someone check it out and make sure turbos are the only issue, they don't generally die on their own and there is a chance they can do other damage
Why?
can always put the shit lag wagon twins back on.
A weekend in the garage and it’s “as it was as Nissan intended” or some other dribble that GTR guys love to froth over.
As Brett said, -7’s/-9’s or if you want a bit more poke a set of -5’s. The as it’s been for the last 20 years.
  • Haha 1
It's not 2010 anymore mate, the world has moved on. An R series GTR is no longer for making big power out of, breaking parts that can no longer being replaced, leaving in the garage for years, then repeat.
It is for keeping standard as possible, putting genuine nismo accessories and maybe some period rays wheels on, and shipping to the US when you win GTR lotto.
People don't have to like change but it happens anyway. Ask anyone who wanted to own a GT Falcon or even a Torana in the last 20 years.
  • Like 2
Since the turbos are coming off, might as well pull out the motor for ease and at the same time add in a head drain/sump breather, Nitto oil pump, extended baffled & gated sump, fresh bearings, ARP stuff top to bottom, Nitto OR Tomei head gasket, all fresh seals.
If money permits, a Samsonas too.
Who the f**k pulls the engine out to change turbos? I can have a set of turbos out of a gtr in about 2hrs,
better ring maatouks, crd, jem and etc and let them know what GTRs are for now because they’re building more then ever and finished examples are fetching huge money
  • Like 1
A lot of workshops I talk to don't even do intake plenum/collector with the engine in the car.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
