Heya folks,
Just got home from a drive and my turbos decided to shit themselves.
I actually had it up on the market but now it looks like that's being put on hold till the issue is fixed. :(
The car is in amazing condition and I don't want to do any big single upgrades or anything like that. Since I'm pulling them out may as well put something a little better in there.
Any recommendations on some decent twins that aren't going to break the bank?
I don't want to have to change the manifold or anything like that so it would have to be something that bolts straight in.
Thanks in advance!
https://www.sau.com.au/forums/topic/483574-twin-turbo-upgrade-r33-gtr/
On 20/04/2022 at 3:11 PM, robbo_rb180 said:
Either rebuild what you have by @hypergear, find a second hand set or 2860-9 upgrade.
Exactly. 2nd is quicker to do and might cost a little more, and you will get 20% more whoosh.
You'd be mad to convert a GTR from twins to single these days unless it is for genuine race only use
https://gcg.com.au/turbo-charger-kit-nissan-rb26-low-mount-iwg-gt2860r-9-xtr000908i.html?ref_cat_id=Turbo-Upgrades-Kits-Petrol-Turbocharger-Kits
This what you boys mean by the -9s?
Also, while we're here - since they're blown and the car is sounding like a hilux, does this mean I shouldn't be turning it on at all and tow, or is it ok to not hit boost and drive it to the workshop?
Edited by Mlads33
I wouldn't allow the engine to turn until you've verified that you haven't gotten a bunch of ceramic bits from the turbine going backwards from exhaust gas reversion. Letting off at high rpm you can see the manifold pressure reach high levels of vacuum.
Edited by joshuaho96
Yes, those. That kit includes the slightly different oil drain fitting you need.
And no, don't run or drive it. Depending what has happened exactly there could be crap all through your oil. Also, it is worth having someone check it out and make sure turbos are the only issue, they don't generally die on their own and there is a chance they can do other damage
Why?
can always put the shit lag wagon twins back on.
A weekend in the garage and it’s “as it was as Nissan intended” or some other dribble that GTR guys love to froth over.
As Brett said, -7’s/-9’s or if you want a bit more poke a set of -5’s. The as it’s been for the last 20 years.
  • Haha 1
It's not 2010 anymore mate, the world has moved on. An R series GTR is no longer for making big power out of, breaking parts that can no longer being replaced, leaving in the garage for years, then repeat.
It is for keeping standard as possible, putting genuine nismo accessories and maybe some period rays wheels on, and shipping to the US when you win GTR lotto.
People don't have to like change but it happens anyway. Ask anyone who wanted to own a GT Falcon or even a Torana in the last 20 years.
  • Like 2
Since the turbos are coming off, might as well pull out the motor for ease and at the same time add in a head drain/sump breather, Nitto oil pump, extended baffled & gated sump, fresh bearings, ARP stuff top to bottom, Nitto OR Tomei head gasket, all fresh seals.
If money permits, a Samsonas too.
Who the f**k pulls the engine out to change turbos? I can have a set of turbos out of a gtr in about 2hrs,
better ring maatouks, crd, jem and etc and let them know what GTRs are for now because they’re building more then ever and finished examples are fetching huge money
  • Like 1
A lot of workshops I talk to don't even do intake plenum/collector with the engine in the car.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
