Laundering money by building drag cars for fun and prestige is just another way of emptying cupboards full of dirty drug money
The amount of people laying wads of cash to suppliers, workshops and jewellery stores is astounding
How do people people think that all these "unemployed" people driving around in big dollar cars and bikes, draped in gold do it
The old "I pay cash" is strong in their world
  • Like 2
I'd be interested in a new cast block that is primarily interested in fixing the more obvious issues with the RB26 design. Core shift and thin walls is a big one. Another is oil control. Improving the oil returns and feeds is one thing but what would really make me be willing to drop 8k USD would be a lot of engineering/validation devoted to the block/oil pan to integrate internal scavenge pumps and make the engine capable of surviving 1.3g continuous. Being able to confidently push hard on tracks without being afraid of oil surge/excessive blowby would be amazing for peace of mind. Also not having to drill and route even more hoses and all that fun stuff for crankcase ventilation so it retains a relatively factory look and feel would be great.
I would also want this block to be first and foremost street-oriented. It needs to just work with low p2w clearance pistons.
  • Like 1
1 hour ago, Ben C34 said:
Let's go to the judges and figure out who knew first.
Turns out some.othwr bloke, Steve, knew before any of you.
I reckon Herman knew before Steve though
4 hours ago, r32-25t said:
I said it in an earlier post that they were
Yep, you also said , been years and no eta.
Just thought people would like the offical line and an update on timing.
Forgive me for not crediting your prior post
Didn’t give an eta because I first heard about this years ago and was told at last years gtr fest it would be good to go end of last year and yet here we are with 2 months to go in 2022 and still no block
On 13/10/2022 at 10:13 PM, Butters said:
If so, the someone will have to cut my head off before I buy a fkn shit PRP piece of dump.
  • Haha 1
On 10/9/2022 at 11:31 AM, r32-25t said:
Cast blocks have the issue of the cradle walking and require a fair amount of work to try and rectify.
1/2in head studs are usually desired to keep the head down but the deck ends up weak and cracks.
the bores flex and end up either being oval or crack, also with core shift in the casting process you can end up with thin  spot which either makes them only good for one over bore or not good for even one
Saw this thread on blocks and it takes me way back to dinosaur days with my old Holden red motor sixes and its seems that the same issues with the in line sixes keeps on repeating in regards to main cap and cradle walking.
Got to agree with r32-t on the work that needs to be done on them to get them to survive high horse power applications.
I had to sonic test the blocks I had for wall thickness and core shifting, sleeve them down with thin wall ductile or nodular iron sleeves (can't remember which), grout fill the block.
Also had to machine a cradle or crank brace ( whatever you want to call it ) got a two inch thick block of steal, the length of the motor and width of the sump rails and machine it out to replace the main caps and drill out the sump rail mounting bolts and bolt it all up. Dry sumped it etc etc blah blah blah
This tended to be the best way to get the most strength out of them.
Next engine I built would 100% be the PRP cast block.  They're not stupid so they will cover EVERY weak point of the engine and remedy it.  Yeah $8K is a larger initial investment than either your own existing block or buying a new factory block but you won't need to spend anywhere near as much on it to make it strong enough to handle big power.
It will be interesting to see if they have a base engine with options on top or just have a fully inclusive package.
That was my thinking when I bought the billet block, yes it costs more to begin with but it wasnt much more compared to buying another cast block and doing everything to strengthen it properly and I still would have had a weaker block at the other end
100%.
With a factory block you're always going to be chasing your arse adding to it or assuming at some point it's going boom!
1 hour ago, DaymoR32 said:
how much are greentop barra's these days? 😆
Which one? BA, BF or FG
BA BF = $100 for a long
FG = $150 for a long motor
My mate at work is constantly bending my ear in all things Barra
Not bad for a base that is so capable and easy to build for small change
  • Like 1
still waiting for some to awd sump convert for a gtr install, same with an LS too haha
Seen an awd ford ute with one that ripped..  territory running gear though.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
