Liberty make transmissions for RB 25/26. basic unit is rated for 1500hp and next one up is 3000hp. Come in 3,4,5 speed and unlimited ratios. Clutchless. Prices are in USD but still seem way cheaper then any sequential. These things seem to be just about unbearable. Why isn’t any one using one in a GTR?
Supposedly those are drag-only and can only be shifted up. To go back down a gear requires going into neutral to reset the shifter then trying to rev-match your way into the desired gear.
  • Like 1
Well I’ve sent them a message asking if the transmissions in question are streetable and what’s involved in fitting one. We will se what happens. I’m still surprised that none of the dedicated drag cars run them if they are a proven product in much much faster cars.
  • Like 1
Surprised this hasn't been mentioned, they pop out of gear if you let go of the shifter. So yeah, hand off the shifter and your back in neutral.
So no, not a streetable gearbox for this reason and all the other reasons listed above.
With the way people have to fight the steering wheel in these cars to keep them straight, I’d hate to be having to do that with one hand because of not wanting to end up in neutral if I use both
also if you miss a shift, it’s a rebuild and you need to cut a big portion of the floor out to get everything to fit
  • Like 1
On 19/03/2023 at 9:16 PM, GTSBoy said:
It's totally streetable. It's just that the streets are pretty short and have lots of concrete barriers, lights and a return road.
So applicable... if you live life [drive?] a quarter mile at a time.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
