Redknight Posted May 22, 2017 Share Posted May 22, 2017 1 Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7830702 Share on other sites More sharing options...
Super Drager Posted June 16, 2017 Share Posted June 16, 2017 R32 with RB25DET ebay 3076 .73a/r internal gate Stock mani 3" exhaust Gutted cat 3" intake pipe Plazmaman fmic Forward facing plenum Top feed rail 1000cc injectors 90mm TB Nistune E85 Cousins car tuned at unigroup. Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7835346 Share on other sites More sharing options...
Bumblebee Posted June 22, 2017 Share Posted June 22, 2017 Rebuilt stock Rb25DET Kinugawa T67 25G 8cm, Turbosmart 45 gate 600x300x100mm cooler (cant remember brand) with custom piping. 740cc nismo injectors, walbro 400 fuel pump Apexi power fc 5zigen exhaust, custom dump Stock intake/exhaust manifolds Its insanely responsive as you can see.. 177-179rwkw by 4k.. then around 220rwkw an extra 500rpm later.. pulls like a freight train! Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7836426 Share on other sites More sharing options...
LaurelPWR Posted June 22, 2017 Share Posted June 22, 2017 Update for my setup....Same mods:Motor was rebuilt around 15k km ago witharp rod bolts/head studsacl bearingstreated and prepped oem rods and crankRoss forged Pistons1.2mm cometic gasketTomei poncamsBrand new oem liftersperformance springsApexi power fcturbosmart eboost2R32 gtr itb's4 inch hard intake pipe with apexi pod & z32 afmCusco plumb back air oil separatorsplitfiresQuest 125A alternator740cc nismo injectorswalbro 460 pumpHKS 2835 Pro S 56T 0.87arTurbosmart internal gate actuator hpi turbo manifold, exhaust special hks 2835 pro s dump pipe into a genuine hpi split front pipe into straight through 3 inch exhaust with no mufflers or cat etc...... Runs United E8524psiSome small mods to my actuator yielded better spool, response and held boost stronger resulting in a 15hp better peak and 100hp gain at 3700rpmIt's a blistering setup and an almost unbeatable street car being a light weight and highly tuned semi stripped s13 chassis and even my 315/30 nitto Nt01's can't get the power down anymore hahaResponsive!!!! 3 Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7836484 Share on other sites More sharing options...
hypergear Posted June 22, 2017 Share Posted June 22, 2017 Unopened R33 Rb25DET HyperGears 21U G3 high flow internally gated 600x300x76mm cooler kit. 1000cc ID injectors, walbro 470 fuel pump Apexi power fc 3 inches Turboback exhaust 20psi @ 3500RPM, 291rwkws E85 fuel Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7836524 Share on other sites More sharing options...
drpheel Posted June 23, 2017 Share Posted June 23, 2017 S1 rb25, Wiseco pistons, BC rods, Cosworth metal HG, all ARP hardware, Greddy intake Bullseye power s259 turbo t3 .76 twinscroll, Precision 44mm gate on a trust style manifold SARD 800CC, TOMEI fpr, Aeromotive stealth pump JUN crank collar, N1 oil pump, tomei oil restrictors 521whp @ 29psi on a dynapack Base tune only, missing poncams and +1000 rpm on the clock (redline at 7000) Will hopefully post the next results before the end of the summer 1 Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7836611 Share on other sites More sharing options...
K-LESS Posted July 22, 2017 Share Posted July 22, 2017 1996 Nissan Skyline R33 Gts25t SII RB25det fully rebuilt with Metal Head Gasket etc. Kelford Cams. RIPS Front Facing Plenum RIPS Sump. Tial 38mm External Wastegate HKS EVC-S Boost Controller Masterpower Custom Turbo. Unsure of Specs. Have been told it is a GT37. Nismo Fuel Pump. Front Mount Intercooler. Apexi Power Intake 440cc Injectors from WRX Sti Sard Fuel Pressure Regulator BP Ultimate 98 Fuel. Oil Cooler and Greedy Oil Filter Relocation Block with Thermostat. Extreme Clutch. Braided Lines through out Apexi Power FC 300zx AFM 1 Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7841036 Share on other sites More sharing options...
Aestysu Posted July 24, 2017 Share Posted July 24, 2017 95 r33 skyline Unopened rb25det Stock Injectors, maf, fuel pump, airbox Power fc Blitz return flow Splitfires Hypergear 21u high flowed g2 profile at 18psi Avcr Maf and Injectors maxing out. This seem alright to you guys? or could I squeeze some more without upgrading Injectors, maf, etc Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7841307 Share on other sites More sharing options...
Vlt wag Posted August 7, 2017 Share Posted August 7, 2017 Vl turbo Standard 25 refreshed Ffp and to4z garrett 272 cams and gears Ems ecu 800cc siemens injectors 407 hp revving to 7800rpm on 12 pound Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7843393 Share on other sites More sharing options...
klutched Posted September 6, 2017 Share Posted September 6, 2017 R33 GTSt S2 Tomei headgasket ARP studs Tomei 256 poncams Performance Valvesprings Gt3076r-wg 1000cc injectors Powered by a Link G4+ plugin Needs crank trigger kit 496whp on E85 20psi 460whp on P98 18psi 1 Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7848335 Share on other sites More sharing options...
hy_rpm Posted October 8, 2017 Share Posted October 8, 2017 R33 gtst s2 Rb25det Just jap exhaust cam gear retarded 2• Small hi flow turbo unknown possibly mtq with a r32 turbine housing Silcone intake z32 afm k&n panel std airbox R32 actuator Eboost street 16psi dropping to 14psi S15 480cc inj Blitz return flow fmic Hks dual 2 5inch catback and 3inch jjr dump and hi flow cat Dw300lph fuel pump re earthed Z32 ecu nistune tune by evan [mention=93559]unigroup[/mention] engineering 209rwkw on 16psi tappering of to 14psi Replaced the actuator with a hypergear 1bar item as boost controller was on 100% duty now on 18psi tappering to 16psi 80% duty comes on boost like standard but dont have to worry about the ceramic turbine coming off Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7853427 Share on other sites More sharing options...
Chuki Posted October 15, 2017 Share Posted October 15, 2017 (edited) A31 Cefiro Haltech Platinum plug and play R32/R33 RB25 NEO forged internals Arp head studs, mls head gasket springs/retainers, 260 type B Tomei cams Gtx3076r 1.06A/R twin scroll 6boost T3 exhaust manifold Custom 3" exhaust turbo back 50mm Turbosmart gate plumed back Greddy plenum, 1250cc Bosch injectors, Turbosmart FPR 1200 fuel reg Walbro 460Lph fuel pump Running Flex tune E85 Made: 441hp on 21psi (BP98) 522hp on 24psi (E85) 530hp on 30psi (E85) Loosing boost at high boost levels, suspecting a leak so there is more left in the setup, looking at getting a Plazmaman Intercooler and getting a bunch of stuff rapped up in order to try lower the IAT, climbing towards 50 degrees Celsius at the moment. But the car is very fun to drive, going to E85 is a huge difference, for anyone thinking of converting... Do it its totally worth the money spent on parts. I think the rpm on the dyno might have been a bit off on the day because last tune one the same dyno i was hitting full boost at 4200 rpm. The car feels very responsive Edited October 15, 2017 by Chuki Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7854379 Share on other sites More sharing options...
mikel Posted October 27, 2017 Share Posted October 27, 2017 On 8/10/2007 at 9:56 AM, mikel said: Update just had a retune 9 Aug 07 no mods from below except 98 RON BP ultimate more timing added with the boost sneaking to 16PSI then dropping back to 13.5 PSI 235 rwKW cheers Mike I wish that I'd posted the dyno graphs back in 2007, as I can't find them now, but I suspect that the 235 rwKW back in 2007 was likely the dyno reading a little high, given it had standard injectors and fuel pump at the time... Fast forward to 2017, the engine is now a NEO top and bottom with "unknown" aftermarket cams, R33 sidefeed 555 injectors, Walbro 155 LPH fuel pump, turbotech bleed valve, PowerFC, steel suction pipe, HKS 25/30 turbo. 234 rwKW - tuned by Anthony (Guilt Toy) at EFI Performance Tuning in Newcastle https://www.facebook.com/tunedbyanthony/ cheers, Mike Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7856445 Share on other sites More sharing options...
Stick180 Posted November 28, 2017 Share Posted November 28, 2017 C34 Stagea S2 Unopened RB25DET Neo Stock Intake and exhaust manifold (modified with 12mm T3-T4 spacer) Borg Warner Airwerks S257SX-E 0.83 T4 split pulse Tial MVR 44mm external gate on rear housing 3" Turbo back exhaust, Highflow cat, HKS Super drager muffler Nistune with flex sensor and feature pack 2 1250cc Bosch injectors Walbro 485 fuel pump Bosch R8 coilpacks Greddy Profec B spec II EBC Rev limit dropped to 6800 Has a boost leak, boost drop at about 5500rpm to 17 psi Made 266rwkw on 98 @ 18psi Made 302rwkw on e85 @ 19ish psi Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7860466 Share on other sites More sharing options...
V28VX37 Posted February 4, 2018 Share Posted February 4, 2018 R34 GTT sedan manual: Hypergear ATR43-SS2 internally gated on stock manifold Rebuilt actuator arm with preload Stock airbox and snorkel Ryco panel filter New Z32 AFM and plug Scotty's 3" intake pipe Trust turn flow intercooler Blitz Dual SBC Spec R EBC (dual solenoid) Splitfire coil packs NGK BCPR6ES-11 spark plugs regapped Deatchwerks 800cc injectors Walbro F90000274 450L/hr fuel pump E85 safe Fuel pump direct feed rewire from the battery, 8-gauge wire Fuel tank lid rewire with bulk head terminals (Feb 2018) Magnafuel fuel regulator JJR 3" bellmouth front/dump (modified) Venom 5" body high flow cat PEX/Berklee mid muffler 3" HKS Super Drager rear muffler Full manual conversion using R34 gearbox and parts Nistune Result: 318rwkw @ ~20psi, United E85 This confirms that the: Stock airbox Basic panel filter Trust turn flow intercooler all go past 300 rwkw 4 Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7866850 Share on other sites More sharing options...
pogman Posted March 21, 2018 Share Posted March 21, 2018 R33 gtst s2 manual:Gt3582r .82 rear housing on a custom manifold externally gated and plumbed backForged pistons, rods, arp main and head studs with 1.5mm metal headgasketStock head fresh refurbish with tomei drop in 256 cams460lph intank pump direct relay from battery with bosch 1000cc injectors4 inch from turbo to 3.5 inch through high flow cat and 4 inch tip440.2 whp at 20psi with united e85Needs alot more mid range not sure what is really holding it back my guess being a shit manifold or old spec turbo. Keen to hear some thoughts Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7870724 Share on other sites More sharing options...
klutched Posted March 21, 2018 Share Posted March 21, 2018 11 hours ago, pogman said: R33 gtst s2 manual: Gt3582r .82 rear housing on a custom manifold externally gated and plumbed back Forged pistons, rods, arp main and head studs with 1.5mm metal headgasket Stock head fresh refurbish with tomei drop in 256 cams 460lph intank pump direct relay from battery with bosch 1000cc injectors 4 inch from turbo to 3.5 inch through high flow cat and 4 inch tip 440.2 whp at 20psi with united e85 Needs alot more mid range not sure what is really holding it back my guess being a shit manifold or old spec turbo. Keen to hear some thoughts Probably cause you put a 1.5mm HG on it lol. Wind the boost up. I'd put a 1.2 back in and wind the boost up for sure with a built bottom end. I'm running an old spec 3076 on a CRG mani external gate with fresh head and tomei poncams, stock S2 bottom end, only a 3" custom dump and exhaust and made 500.9whp on 20psi E85 through the manual, now 444.9whp through the glide. Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7870745 Share on other sites More sharing options...
Dose Pipe Sutututu Posted March 21, 2018 Share Posted March 21, 2018 11 hours ago, pogman said: Gt3582r .82 rear housing on a custom manifold externally gated and plumbed back Stock head fresh refurbish with tomei drop in 256 cams 4 inch from turbo to 3.5 inch through high flow cat and 4 inch tip 440.2 whp at 20psi with united e85 Needs alot more mid range not sure what is really holding it back my guess being a shit manifold or old spec turbo. Keen to hear some thoughts is your VCT working? I would check that.. also see if your timing belt is on properly and both cam gears are aligned. Run more boost too, don't be a pussy 1 Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7870749 Share on other sites More sharing options...
pogman Posted March 22, 2018 Share Posted March 22, 2018 Probably cause you put a 1.5mm HG on it lol. Wind the boost up. I'd put a 1.2 back in and wind the boost up for sure with a built bottom end. I'm running an old spec 3076 on a CRG mani external gate with fresh head and tomei poncams, stock S2 bottom end, only a 3" custom dump and exhaust and made 500.9whp on 20psi E85 through the manual, now 444.9whp through the glide. The head gasket was recommended by the mechanic when doing a freshen up on the engine and as a newbie i just went with it, whats the advantage of thr 1.2mm hg over the 1.5mm? Will definitely crank the boost up once i get used to this power abit more but would like a surge set up first. Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7870807 Share on other sites More sharing options...
pogman Posted March 22, 2018 Share Posted March 22, 2018 is your VCT working? I would check that.. also see if your timing belt is on properly and both cam gears are aligned. Run more boost too, don't be a pussy [emoji4]I will definitely check those when i next get the chance and may potentially take it to a different shop to see what they can get out of it. More boost is definitely on the card soon Link to comment https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page/57/#findComment-7870808 Share on other sites More sharing options...
