I'm rolling on Bridgestone Potenza RE-01's now.
245/40 R17 front and 255/40 R17 rear
They're not a bad tyre. I've got the pressures way up, and so its quite responsive. Outright grip isn't bad - I didn't manage to throw myself off the road.
Give me some time to wear the blacking off them, and when I'm not with n00bs like I was this morning, and I'll give them a proper run.
Cool, How much did that set you back? how did you get them in the first place? I have some on my rears same size, came with the rims with plenty of meat. Havent given them a full flogging yet. Do they put down power allright?
I don't have much power to put down, but they do a good job.
I got them privately imported. They weren't cheap (actually they were a fair bit more than I intended to pay) but we'll see how they get on as they wear.
Bridgestone RE-01 225X??x17 Front
Sh!thouse tyre, soo much understeer its not funny! Going into banked right hander at about 70 the front starts to slide. WOuldnt get them again.
Hankook K104 255x35x17 Rear
Awesome tyre! Can't break traction in 2nd, 3rd etc but breaks it on uneven roads in first (190rwkw). would get these tyres again definately. Also i got them for $250 each and can do anytime.
anyone using the advan sport v103? or yoko avs v102? since am intrested in switchin my rear tyres soon.....have been tryin to find out more abt them than wots been told to me over the counter.....anyone with some insight??????? :
Has anyone had a look at the Advan A046. i have got a really got price on a set but am tossing up between these and the toyo t1-r's. They came out stock on the Evo VIII's so they would have to be pretty good. T1-R's are looking like they will be an extra $70 or $80 a tyre at this stage.
provide a link 4 the description of the A046, cuz i cant find it on the aus yoko site..... :
hmm good point very strange that the Aussie site does not list them at all. The reviews seem good and they came out on the evo's as i mentioned. I think i will stick with the Toyo T1-R's so far i have managed to get a price of $280 a corner but should be able to get that down a little lower :D
This is for a 235/45/17
http://www.tirerack.com/tires/tires.jsp?ti...odel=ADVAN+A046
Its been raining in Melbourne, and I have to say my Bridgestone Potenza RE-01's are sucking some major ass right now. There's so little grip in the rear end its not funny. I've tried to run high pressures, cold pressures, and the rear just won't stick.
In the dry they're not exactly magic either.
Falken Ziex 326
Dry: 2/10
Wet: 1/10
Value: 0/10
Compliance tyres. Certifiably dangerous in the wet at speeds slower than the slowest camry. Put a big scratch in
my stock rims when i had them on due to taking a corner in the wet too fast...at 30km/h
Falken ST115
Dry: 4-5/10 (cold)
6/10 (warm)
Wet: 6/10
Value: 6/10
Theres a big difference when these tyres warm up. When theyre cold, they are as bad as everyone says, they change a lot when theyre warm though. I quite liked them when they were warm, but in the
back of my mind i was always scared that they would let go while really pushing them. When it slides, its
not really progressive.
Stiff sidewalls though makes for responsive turn in though (relative to street tyres)
Hankook k104
Dry: 7/10
Wet 6/10
Value: 8/10
Similar price to falkens execpt they grip better and seems like its going to last longer. Really good performance in straight lines (launching and braking). Better grip than falkens without the need to warm up the tyres. Also very predictable loss of grip so you feel safe pushing them.
Soft sidewalls though, so ride is softer, but not as responsive.
For a street tyre around $200 i would recommend the hankooks. I wish i could buy better tyres, but I do 25 000kms a year, so i need a balance of grip and durability, not R type tyres which last 10 000kms.
Anyway, im pretty happy with the hankooks though, but i will spend more if theres a better tyre which lasts just as long.
Heres a comparo i did of the st115 and the k104
http://www.skylinesaustralia.com/forums/in...dpost&p=2090267
Toyo T1R's are great, After 100Km I have to rate them better then my Yoka Aspecs and the piolot sprots I had on the 33. Im very happy.
Toyo T1R
9/10 Dry
9/10 Wet
6/10 Value (They do cost a bit)
Yoka Aspec
7/10 Dry
8/10 Wet
10/10 Value (1/2 the cost of the T1R)
Mich Piolot Sports
8/10 Dry
9/10 Wet
6/10 Value ( Very expensive)
After 16,000 I had to retire my T1R's I had torn a steel band on the front right and the rubber was pulling away. Except for the life of the tyre I was very happy with them. I did about 5 track days and distroyed the edges and still had some tread depth left. If the tyre had of held together I probably would have got another 4000km out of them, but could not have run another track day on them.
I have just gone with a Yoka E300, These are not performance tyres, but are doing the job. I dropped 1.5 sec at OP Sth cct, so they are no way as good as the T1R's, as you would expect.
Yoka E300
6/10 Dry
5/10 Wet
8/10 Value
265x35x18 $375 each
I expect to get 25-30,000 km out of this set.
Im still on the lookout for some second hand semi's as track set of rubber. If anyone has some please let me know. GTR R34 Rims 18x9's
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
