apprently the 260rs brake pads are the same as the 33,34gtrs for the front and i would susprct th rers are the same. they share the same part numbers
of course they are :whistling: the brembos are r33 gtr items on 260rs's, and the r34 ones are identical but painted gold instead. so brake pads would be exactly the same :laugh:
beKW FLUIDS QIAE AHOULD I JUAT UAW dor 4 onwa or go for the dot 5?
Also i've heard that if we keep on changing different brand of brake fluid its not good for the rubber seals in the brake system is that true?
wtf does that say? :whistling:
one tip is to re-read your posts b4 u add them as typos just make it sooo hard to read
no offence it just shit me haha, take a look over it once u post to see if its readable :D
thanks mate
hd;ofn;sdffndsfbf/e34[8fdjcdsjb/sd :laugh:
Edited by CruiseLiner
soz my son was playing with me and got distracted.
Anyway what i mean is brake fluids are there much difference between DOT 4& 5?
I've heard also about if we keep on switching brands when we change the brake fluids it will screw up the seals? Can anybody enlightened me please.
As far as i heard from Race brakes, they said it won't damage your seals. Also any brand of DOT4 is the same.
The difference between the DOT4 & DOT5 is the Boiling Temperature. DOT5.1 have a higher temperature rating and of course it's a higher quality brake fluid than DOT4.
wtf does that say? :(
thanks mate
hd;ofn;sdffndsfbf/e34[8fdjcdsjb/sd ;)
f**kING GOLD!!!!
HHAHAHA
I had the same reaction. I started reading and thought, what the hell is he trying to say, LOL...
  • 2 months later...
  • 1 month later...
has anyone confirmed yet that the R33gts (DBA 4963) rotors bolt on to the s2 front with some outside diameter machining ???? the was some talk of them touching calipers, has anyone done this to their s2, or something different they can share.
What about R34 Gtt rotors and calipers on front and back, would this upset the brake bias significantly ? thanks
Edited by chook
  • 1 month later...
Hey huys im a little conf*cked.
i want new pads for the S1 had a look at that autospeedbits site and tried to work out from the selection list they have what i need for the front and back, but had no luck.
http://www.autospeedbits.com.au/resources/...BrakesList.html
here is my question:
are the pads on the front and rear the same as the r33gtst/gtr or the r32gtst/gtr.
sorry again but i have read this thread front to back and all i want is a descent set of pads.
thanks for any help in advance cheers again
Clint, I believe it's DB1250 for the front, and DB1144 for the rear, assuming you're still running the standard s1 brakes.
Unfortunately, they're only two-spot brakes on the front, and one-spots on the rear, as opposed to 4-spot F and 2-spot R on the R32 GT-R and GTSt, and R33 GTSt.
  • 1 month later...
So no one has found s2 stagea front pads yet,
I have spent heap of time trying to match up a set and the closest i came was a set of 'rdb 1439' they are slighltly longer and need some machining down to fit app 3mm per side.
The other day at work i was working on a 2005 subaru liberty gt i saw that the pad looked very familiar so i measured it ....157mm in length same as s2 stagea. So i will be checking this out shortly and hopfully it will put an end to all s2 stagea owners worries... :D
but if anyone else has a solution already please let us know...
and thanks
and thanks
ok it's not the 2005 subaru liberty gt but they are the closest fit as they are 157mm and only require alittle cutting and they will fit.
alternitively change to brembos GTR...or 4 piston GTS-T but yo may have to change the offset of your wheels or use spacers :P
R33's came with 16" standard. :O
its to do with the way the spokes are at the back of the rim, that determines if they will fit or not.
skyline brakes apparently need a 'high clearance' type rim, ie. one that the back of the rim is quite flat, or curves very close to the rim itself, not like alot of those rims that curve in to give them the 'dish look'
my rims only just clear gtr brembos and they are abit dished, but its the spoke design that allows clearance in the right area...
heres a pic of the clearance with my 17' rims... (i think its about 10mm max)
i find the brembos a great upgrade and very much worth the $$$ if u got reasonable horsepower and wanna stop safely :O
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
