what is a good offset for a 18*8 rim for a R32 GTS-t also was thinking of having 235/40/R18 fronts and 265/35/R18 rears. is this a good idea
thanks
if you want 265 on the rear go for 9' wide on the rear,
anything with an offset between +30 and +38 will be fine (if i remember right stock is +35 front, +38 rear)
ne here rollin on 20's ? or are u all on 17s and 18s
Skyline model = V35 Sedan
Wheel diameter = 17"
Wheel width = 7"
Wheel offset = 45
Tyre size = 215/55/17
Modifications to fit = Non car is stock at the moment.
Have you tried to buy 20" wheels in the right width and offset for a skyline or any car for that fact.
I am looking to fit
Front 20 x 8.5 +35 245/35/20
Rear 20 x 9.5 +45 275/30/20
So far have only found one set but everyone at the office thinks they are ugly.
My car is pearl white.
Any ideas or help would be appreciated.
R33 GTSt
Wheel type= Rays Gramlight 57S
Wheel diameter = 18''
Wheel width = 8.5 Front, 9.5 Rear
Wheel offset = +30 Front, +38 Rear
Tyre size =235/40/18 Front, 265/35/18 Rear
The car has stock suspension, no mods to fit; no rub on front at full lock, rears still fit in guard no overhang at top. No need in really going much bigger on a R33 GTSt but that hasn't stopped any one before. whatever, whatever.
Edited by 95skyline
everyone at the office is correct
Not the help I was looking for but everyone is entitled to their own opinion even if they only have 17's :laughing-smiley-014: .
V35 350GT
Wheel type= BSA Wheels AU 213
Wheel diameter = 20''
Wheel width = 8.5 (F) 9.5 ®
Wheel offset = +35 (F) +45 ®
Tyre size =245/35/20 (F) 275/30/20 ®
They fit with no modification, no rubbing on full lock and turning in on driveway. Ride is not harsh conering is better (obviously) rolling diameter is so close to original it doesn't effect speedo or acceleration.
Pic's to follow later.
V35 350GT
Hi guys,
Just wondering how 18x9 +25 front and 18x10 +25 rear would fit on a R33 GTS-T?
How much modification to the guards would be needed, a bit of rolling, possibly some wider front guards?
I have seen these sizes and offsets fitted to a 180sx which I believe has 25mm wider front guards and rolling done on the rear. They fit nicely, stick out a bit at the rear end.
I would imagine an R33 would have more room under the guards than a 180sx, especially at the back?
Cheers
Skyline model = R32 GTST
Wheel width =9"
Wheel offset =+20 & +30
Tyre size =215/225/235x45xR17
Modifications to fit = Rollage of gaurd on front and rollage and slight flare at the back!
yes they will fit!
Will these fit on the R32 gtst?
I dont want to lip guards and will i have any troubles with scrubbing?
Looking for wheels which will cause no legal problems :)
R32 GTST
F: 17x8 +30 with 235/45
R: 17x9 +30 with 235/40
front wheel (stock offset 25)
The clearance from stut housing to the inside of the wheel will be 18mm LESS
The outside edge of the wheel will EXTEND an extra 8mm
back wheel (stock offset 38)
The clearance from stut housing to the inside of the wheel will be 5mm LESS
The outside edge of the wheel will EXTEND an extra 21mm
Thanks
I've got 17x8 and 17x9 with +30 offset front and rear.. 235/45/17 all round
so, front will be fine but rear u need to lip and flare the guards (if car lowered)
How low can i go without scrubbing?
Curently have some shocks/springs which may drop height down to 340mm
Rekin, that "clear r2 indicators" link in your sig is broke...
link fixed now :)
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
