what is a good offset for a 18*8 rim for a R32 GTS-t also was thinking of having 235/40/R18 fronts and 265/35/R18 rears. is this a good idea
thanks
if you want 265 on the rear go for 9' wide on the rear,
anything with an offset between +30 and +38 will be fine (if i remember right stock is +35 front, +38 rear)
ne here rollin on 20's ? or are u all on 17s and 18s
Skyline model = V35 Sedan
Wheel diameter = 17"
Wheel width = 7"
Wheel offset = 45
Tyre size = 215/55/17
Modifications to fit = Non car is stock at the moment.
Have you tried to buy 20" wheels in the right width and offset for a skyline or any car for that fact.
I am looking to fit
Front 20 x 8.5 +35 245/35/20
Rear 20 x 9.5 +45 275/30/20
So far have only found one set but everyone at the office thinks they are ugly.
My car is pearl white.
Any ideas or help would be appreciated.
R33 GTSt
Wheel type= Rays Gramlight 57S
Wheel diameter = 18''
Wheel width = 8.5 Front, 9.5 Rear
Wheel offset = +30 Front, +38 Rear
Tyre size =235/40/18 Front, 265/35/18 Rear
The car has stock suspension, no mods to fit; no rub on front at full lock, rears still fit in guard no overhang at top. No need in really going much bigger on a R33 GTSt but that hasn't stopped any one before. whatever, whatever.
Edited by 95skyline
everyone at the office is correct
Not the help I was looking for but everyone is entitled to their own opinion even if they only have 17's :laughing-smiley-014: .
V35 350GT
Wheel type= BSA Wheels AU 213
Wheel diameter = 20''
Wheel width = 8.5 (F) 9.5 ®
Wheel offset = +35 (F) +45 ®
Tyre size =245/35/20 (F) 275/30/20 ®
They fit with no modification, no rubbing on full lock and turning in on driveway. Ride is not harsh conering is better (obviously) rolling diameter is so close to original it doesn't effect speedo or acceleration.
Pic's to follow later.
V35 350GT
Hi guys,
Just wondering how 18x9 +25 front and 18x10 +25 rear would fit on a R33 GTS-T?
How much modification to the guards would be needed, a bit of rolling, possibly some wider front guards?
I have seen these sizes and offsets fitted to a 180sx which I believe has 25mm wider front guards and rolling done on the rear. They fit nicely, stick out a bit at the rear end.
I would imagine an R33 would have more room under the guards than a 180sx, especially at the back?
Cheers
Skyline model = R32 GTST
Wheel width =9"
Wheel offset =+20 & +30
Tyre size =215/225/235x45xR17
Modifications to fit = Rollage of gaurd on front and rollage and slight flare at the back!
yes they will fit!
Will these fit on the R32 gtst?
I dont want to lip guards and will i have any troubles with scrubbing?
Looking for wheels which will cause no legal problems :)
R32 GTST
F: 17x8 +30 with 235/45
R: 17x9 +30 with 235/40
front wheel (stock offset 25)
The clearance from stut housing to the inside of the wheel will be 18mm LESS
The outside edge of the wheel will EXTEND an extra 8mm
back wheel (stock offset 38)
The clearance from stut housing to the inside of the wheel will be 5mm LESS
The outside edge of the wheel will EXTEND an extra 21mm
Thanks
I've got 17x8 and 17x9 with +30 offset front and rear.. 235/45/17 all round
so, front will be fine but rear u need to lip and flare the guards (if car lowered)
How low can i go without scrubbing?
Curently have some shocks/springs which may drop height down to 340mm
Rekin, that "clear r2 indicators" link in your sig is broke...
link fixed now :)
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
