Above dyno sheet engine specs. I'm taking a cue from whats above so this is what I know.
N1 Block.
RPM 2.8 build. (don't know huge details)
Garret 2860-5 Turbos
RPM 4inch exhaust (twin 2.5 in tips)
HKS Vcam
HKS Cam Gears
E85 set up (Pumps etc)
Power FC
120mm intercooler
N1 oil pump
N1 water pumps.
Sard 700cc injectors
Nismo AFMs
I think thats all thats relevant. Has sump mods etc as well but figure not making a difference as far as power goes.
  • Like 2
N1 Block.
HKS Vcam
HKS Cam Gears
Power FC
120mm intercooler
N1 oil pump
N1 water pumps.
Nismo AFMs
Wow - cool setup. That must have cost a pretty penny to setup?
E85 on 700cc injectors?
I'll check on injectors as the car came with two sets and one of them was the ones we used but they may be 1000cc. Seems more likely.
It cost a bit. I'll say no more :)
Mick.
  • 2 months later...
Just got my car tuned 703rwhp 524rwkw. Does anyone know the record for these turbos?
Built bottom end with 87mm pistons
2860-5 turbos
Pon cam type A
Tomei manifolds and dumps
Apexi down pipe
ID1000s and tomei fuel rail
2 walbro 400lph fuel pumps
Nismo inlet pipes and hard intercooler pipes
Custom intake pipes
AEM series 2 ecu tuned for flex fuel
4CA2765D-A61C-43E6-9DCF-9E05E902C893_zps
2860-5 turbos
Pon cam type A
Apexi down pipe
Custom intake pipes
I think you're the record holder if the above dyno read out is accurate.....wow
2860-5 turbos
Pon cam type A
Apexi down pipe
Custom intake pipes
Really?
Judging by when that peak touqe hits they could be -10's.
Is this on std standard stroke, so a bit over 2.6?
What intercooler you running?
What exhaust?
What boost achieved that number?
Really?
What exhaust?
These are -5's I have a picture somewhere.
Block is built with 87mm pistons, eagle rods, and N1 crank
Stock Intercooler
When I bought the car the previous owner said the exhaust was blitz. The muffler says Kakimoto
We are running 25psi of boost.
Here a pic of the engine
00000000-0000-0000-0000-0000000000ED_zps
Here's a pic of the new inlet pipes
A7AF15C8-183C-4845-B030-E13041C0BC9E_zps
We are using E85. The 1000cc injectors are maxed out already so might have to change those out. Powerfab rents out the local drag strip in April to fine tune cars so I'll post trap speeds then. Also we are taking the car to another dyno this week.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
