ah nice nice..
what kit?
i might contribute to this thread while im here..
what grinds my gears - removing more skin than engine parts whilst attempting to do my engine swap!
What happened to the days of people driving imports acknowledging each other with just a thumbs up or something ..... people are getting way too snobby haha. When i had my Z31 every second silvia i went past waved and on the odd occasion a skyline driver would wave.
That never happens anymore..... theres just no love.
I get the same, I only wave/thumbs up to other skylines but I'm yet to find out to do it back :O The only contact I get with others are the ones that pull up quickly alongside you, but then dont look over. ;) The same after a run with someone, people that lose never seem to give a thumbs up.....
I did get a thumbs up from a 99 xr6 & his passenger though haha
Hahaha just came in here to say the same...
I do admit though I'm a little embarrassed but I always look over at them or spy them in revision mirrors with a smile and even though I was full of dots on Monday (hahah) they could of smiled back :( lol
What also grinds my gears are computers that decide to blow a fuse when there is nothing open on a long weekend GRRR!! and your stuck at home sick :laugh:
What shits me is when I come home and find my letter box all caved in and my welcome sign on my gate smashed up in bits... have a strong feeling i know who it is seeing as i saw his car drive past my house a couple times... when he clearly has no need to be in my area - I live in whoop whoop... oooooooh revenge is so sweet - especially when they drive 70K cars ... payback's a bitch :)
AGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
gears are to ground to even express in type
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
