  • 1 year later...
Hey everyone, am nearing completion of my RB25/30 build, but I seem to be stuck on setting up the timing.
I have drilled and tapped the block above the water pump for the timing belt tensioner, am using a RB25 idler below the water pump, crank is at TDC, but am unsure on where my cams are supposed to be at. I also have adjustable cam gears to go onto the cams, once the motor in full is set to TDC correctly. To make it easier, the block is a standard A6 VL N/A block, and the head is standard aswell, valves, cams, with the exception of the VVL being blocked off in the head.
If someone could help me out with this it'd be muchly appreciated. Have tried searching in this thread alone and also the whole of SAU, but cant find a definite answer. With 359 pages worth of thread here, I tried looking, but it seems a lot of people like to talk shit in here too which makes it all that much harder..
Install the adjustable cam gears straight off and use the markers as per Ben's comment.  Then pay someone competent to degree your cams.  Hint: this is far easier and less time consuming to do on the bench/engine stand.
  • 1 year later...
Hey team.
Massive thanks for this thread. It's amazeballs.
Just wondering if a factory 25DE ecu could be used to get a 30DET running. Just temporarily so I can check everything for leaks and I'm eating myself noises before it goes for dyno tune.
Not sure what ecu I'm going to use yet will speak to the tuner before to see what brands they are familiar with.
Once again cheers guys
  • 1 year later...
I know....Rb25/30 boredom (not build ) question...but opinions will be cool
Need to know some real Hp/Kw figures for my build...just your guesstimation possibly.
Build
25neo head.+1mm over int/exh..rear head drain
Stainless valves ..performance springs
Tomei cams (poncam)
Ati balancer ...prp collar..n1oil pump..forged gears..prp billet crank sprocket washers...billet backing plate to n1 pump..7L sump.. Stock crank acl bearings...87mm rb30 block..CP flat top pistons...Max peening H beam rods.
Fuel cell...1000hp fuel supply..1400cc injectors.
6boost exh...45mm hypergate.
Haltech elite2000....flex fuel.
Real reason is so i know if my gearbox is going flying...
Build
Tomei cams (poncam)
No turbo so approx 180kw
  • 4 weeks later...
  • 1 year later...
On 19/10/2021 at 11:15 AM, jaychen said:
Is this still the thread to read with regards to high hp sohc rb30 applications?
Most stuff on here will relate to DOHC heads.
What info specifically are you chasing?
  • 2 years later...
Just thought I would bump this 20 year old thread because the Skid Factory have just posted up a video summarising a lot of the content, format might be more familiar for newer members
  • Like 2
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
