just my experience....
bought jjr coils 12mths ago for $399 and after exactly 12 months they failed and caused misfire.....
was lucky to get the warranty.....and upgraded to spitfires.....going good....
Inerested to find this out too, my car does it every now and then, kinda like if i catch it by surprise and shift too soon or somethin.
but anyways I'll be getting a set of yellow jackets next week ive decided, cant wait to see wat they can do for me
I get this also?
Does anyone know what it is?
hm it seems JJR and YellowJackets don't sell any coil packs for R34 GTT's where as SuperSpark do ... I used to think they are all the same chinese coilpacks rebranded but doubt it anymore. If Supersparks were made in the same place as the others, the other sellers would have R34 GTT coilpacks for sale by now.
But anyway ..only a $50 difference between Superspark and Splitfire so might as well go Splitfire if you have an R34 GTT/Stagea (NEO motor)
i burnt out 2 jjr coilpacks within a week and i m currently having spark problems now and they have only been funcitoning for abour 2000 kms
had my yellow jackets for over 5000kms, 2 track days and a motorkhana. pulled them out the other day for inspection and no signs of wear at all, still going very strong :thumbsup:
  • 3 months later...
the JJR ones for series 2 R33's (i think they fit gtr's aswell) were a shocking unit, when i was looking for coils last month i called around and the importers of the JJR's said they were discontinued from sale and they recommended Splitfires, they said some of the JJR ones would last a year, some would last 20 minutes, as far as they told me there weren't any probs with the series 1 r33 style or the r32 jjr coils. But as for series 2 or equavalent even they said not to bother with their own product, atleast they were honest about it to me.
In the end I got splitfires, massive amont of difference from a car who couldnt rev abouve 5000rpm just before i changed the coils... now its like driving a new car
  • 1 month later...
and before anyone on here that knows me starts...yes i know, I AM INDECISIVE :(
lol, are you sure??
just buy yellow jackets or jjr or whatever. If they don't work in your useage they are backed by real australian companies who I'm sure will refund.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
