  • Replies 204
Ok this is baffling. How do I pull the left rear inside off to get to the TV tuner?? M35. Plenty of info for the older stags but none for the M35. If I ever successfully do it Imight put together a pdf of the M35 install.
I took four screws off the top panel, easy slip off. But the carpetted panel beneath it won't come off. I can see one black plastic plug, hard to remove without breaking it but the whole thing sems pretty solidly attached and I'm scared to pull too hard for fear of breaking something.
It can be difficult to get the panel off with out removing the floor. It will come out though with a bit of effort. I think you will have to remove the cover for the tools but this one is reasonable easy.
On the carpeted side panel, there is a black plug that needs to be removed by popping the top out (or maybe screw it), it is a bit difficult and you will need remove the panel next to the passenger seat over the rear wheel arch.
Cheers
Andy
  • 1 month later...
Hey Guys,
Just about to get started on this today, just wondering if i have everything that i need..
M35 stagea with navigation unit/tv.. check
Looms from Chris/audio express.... check
@ work with every little tool i could possibly need...
now do i need rca cables? and can someone give me a brief rundown on how long it will take for a m35 and what needs to be done...
Hey Guys,
Hi Andrew
If you are only doing the TV tuner and not adding any other items at the same time you have all that you need. You didn't mention that you have Chooks TV tuner but I take that as a given.
I would say about 2 hours to do it all.
If you can remove the whole panel in the boot it will make it easier. Make sure you have some thing to secure the 2 TV ariel cables into the new mount. I used shrink cable covers but tape will do it if you are good at wrapping it.
You need to find your power and I can not remember which wire I picked up for that. Craig may remember.
Chooks instructions are very good and very soon you will be enjoying your TV in your heated leather recliner. (perfect for the Vovo driver)
Cheers
Andy
Ahh nice, cheers for that
i've been driving around for the past few days with all the rear trims removed..
i take it i need to remove the stereo/navi unit to plug these things in from chris? is there a rca or something that goes back to the tuner in the back? as i dont have any here.
i also dont have factory bose.. someone pulled it out
OK so after putting all the dash back in place :) hehehe
i am in the rear, got it all apart relay ready to go almost at the stage ready to power up.. but just wondering which wire is the power for the aerials??? just searched the post but couldnt find this info..
i'm taking power from the standard tuner/unit
6 pin plug 5 wires inside. yellow for constant and green for accessories hopefully thats ok?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
