Oh my God I never realised just how Big the new GTR is...! Parked next to the NSX it looks freakin Ginormous..! I had to have a second look as I thought No way...The NSX must be a small scale replica model or something....But no its the real deal
https://www.sau.com.au/forums/topic/209793-gtr-vs-nsx/#findComment-3708582
I'm waiting for hardcore GTR ppls to defend it. I have always said, and ask? does it need those sort of acreage......
Prolly get flame for this. but those fotos just made me laughs.
Just remember I am a hardcore skyline fans, but the latest incarnation have got me lost for words... think Californification...
https://www.sau.com.au/forums/topic/209793-gtr-vs-nsx/#findComment-3708623
Umm last time I was standing next to an NSX I remember thinking how small they are...
Those pictures more brought home how far ahead the nissan is in terms of design than the NSX, gosh it's looking dated already. I suppose some may see that in a good way.
At the Melb Motorshow I had a good gawk at the GTR, it didn't look enormous. Although it gives the impression of being very very wide :D.
Edited by Sarumatix
https://www.sau.com.au/forums/topic/209793-gtr-vs-nsx/#findComment-3708683
mmm....
IMO i dont think it even looks that big. I've seen a NSX before. But for some reason, i don't see the GT-R being much larger, but beside a R34, the 35 is huge. :S
both look good though.
Edited by Owgasm
https://www.sau.com.au/forums/topic/209793-gtr-vs-nsx/#findComment-3708892
good pic sewid, shows the modern car sizing!
Exactly, I've parked the V35 next to an R33 a few times and the size difference looks huge.
It's the way the modern cars are going I guess.
At the end of the day though, personally I think it gives the car more road presence and with the performance the R35 is putting out, who cares how big it is.
Look at the size of most supercars. They need a lane and a half when driving. The only difference is the R35 is taller.
https://www.sau.com.au/forums/topic/209793-gtr-vs-nsx/#findComment-3710044
Well said, size up an original evo to the evo X, or fot that matter, a first gen wrx to the latest abomination (I'm not doubting either's speed btw)
Nothing changes the fact that for better or worse, modern cars are getting bigger and heavier. Blame safety requirements, pedestrian impact laws etc...
Kinda wierd in this "enviromentally aware" age that cars are heading this way, but I think we have to live it up now, 'cause the writing is on the wall..........
https://www.sau.com.au/forums/topic/209793-gtr-vs-nsx/#findComment-3711193
It was designed from the outset to be an internationally sold car, that includes one of their largest markets the good 'ol USofA(ssholes) (I can say that, I used to live there) I think Nissan decided to make *some* provisions for people who aren't japanese.
They can only gripe about it's size and looks because it will absolutely demolish their lesser cars.
BTW: The new STi looks like ass
Edited by Yo-Yo
https://www.sau.com.au/forums/topic/209793-gtr-vs-nsx/#findComment-3712006
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
