spotted a couple of 33's round near work in west heidleberg today round 4.30
one white on waterdale road, nodded
and a silver one at neway wheel repairs (was in work van)
the silver one was me - was asking about powdercoating (they dont do it)
Spotted HOTR34 - around 12:30am at the corner of Princes Highway, waiting to turn right onto Warrigul Road.
Spotted a White GTR R33 Sunday night on Princes Highway, Narre Warren heading city bound.
White R33 with SAU stickers turning onto Belgrave-Hallam rd from Princess Hwy last night... gave me way... appreciated when I'm running :woot:
that was me. i didnt know if u were gonna cross over princess hwy or if u were gonne cross the turn lane.
Spotted dogknight at the row of shops on the corner of High street and Blackburn Rd
Was having dinner at some italian restraunt there. Al.. something or other. Best steak ive had in a long time. Was awesome food. Small dinner for my brothers 21st.
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
