Hey Jessie, wat were u doin on my side of town!! :)
I was seeing my lovely gf :D, she lives around the corner from where your brother crashed. How have you been?
Saw Alan (EXIBIT) and another silver R33 down in Burnside, what were you doing there at that house I know new people just moved in, my gf lives next door :worship: If you can remember i rocked up in that little blue car during the day on saturday, I didnt have my 31 coz it was stuck on a hoist at work lol.
Saw a dirty but VERY LUCKY orange R32 going thru westgarth the other morning.
First time I have ever seen 5 police cars in the space of 100 metres on the way to work.
Two marked skulking around corners at the top and bottom of the hill, one camera car halfway up the hill and another two plains cruising back and forth.
He did not see me waving at him, but for some reason took it extremely slowly going up the hill as if he knew they were around hiding!
Ohh... ...Forgot... ...Saw a green 34 turn left out of a side street near DT panels in Springvale and then turn left onto Springvale road around 2:30 yesterday... ...It looked like it had an SAU sticker... ...but I didn't get close enough to see...
Then I followed a dark blue 33 4-door down Osborn Ave in springvale... ...didn't get a good look at the driver... ...But they did try to make a right turn in front of another car that had to really lock them up... ...Hay D!CKHEAD... ...Don't drive so erratic and hop the roundabouts!!!...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
