  • 3 months later...
Yeah there for sale for $20,000 and the rest of the car comes free :)
But you can get them cheaper here from https://www.ozzytyres.com.au/wheel-and-tyre-packages/hussla-alz-20x8-5-5x114-3-gloss-black-with-machine-tips-wheel-tyre-package
But mine are 19"
HUSSLA SIENNA 19X8.5 5X114 GLOSS
BLACK/MILLED TIPS WHEEL & TYRE
I can't see them in 19" anymore
p.s i had a really bad time with these guys. Wrong rims sent then wrong tyres. Back and forth cost me heaps in time and money.
Edited by V35_Paul
On 8/16/2020 at 3:00 PM, PranK said:
Looks bloody awesome Paul! You enjoying it?
It soooo good.
Going from V35 to V36 felt like only a small improvement but going to the V37(Q60) is a massive change.
I have that same feeling when i upgraded from my 2003 Toyota Camry 4cyl to the 2003 V35
Soooooo GOOD
P.s new number plate yesterday ?
Edited by V35_Paul
  • 5 weeks later...
On 9/19/2020 at 6:04 PM, doggido said:
Are you changing all the badges and how long did it take to align the lettering?
just the rear badges. the front grill would have to be replaced if i wanted to change that.
Not to worried about the side badges behind the front wheels.
I lined them up with my razor sharp eyes :)
In 2016, the US Market got the longer version of the Crossover, here it is Malbec Black in it's transported habitat, Northwest Indiana's Beer Can Beach, Home of Fresh Water Wind Induced Waves that on occasion are Surf worthy, but typically only when frigidly cold. . .   Fair Weather Zed ( we call 'em ZEEs ) also featured in Brickyard in the 1 year only color in 2003
G'day Mates ! ?‍♂️
  • Like 1
  • 3 months later...
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
