  • 3 months later...
Yeah there for sale for $20,000 and the rest of the car comes free :)
But you can get them cheaper here from https://www.ozzytyres.com.au/wheel-and-tyre-packages/hussla-alz-20x8-5-5x114-3-gloss-black-with-machine-tips-wheel-tyre-package
But mine are 19"
HUSSLA SIENNA 19X8.5 5X114 GLOSS
BLACK/MILLED TIPS WHEEL & TYRE
I can't see them in 19" anymore
p.s i had a really bad time with these guys. Wrong rims sent then wrong tyres. Back and forth cost me heaps in time and money.
Edited by V35_Paul
On 8/16/2020 at 3:00 PM, PranK said:
Looks bloody awesome Paul! You enjoying it?
It soooo good.
Going from V35 to V36 felt like only a small improvement but going to the V37(Q60) is a massive change.
I have that same feeling when i upgraded from my 2003 Toyota Camry 4cyl to the 2003 V35
Soooooo GOOD
P.s new number plate yesterday ?
Edited by V35_Paul
  • 5 weeks later...
On 9/19/2020 at 6:04 PM, doggido said:
Are you changing all the badges and how long did it take to align the lettering?
just the rear badges. the front grill would have to be replaced if i wanted to change that.
Not to worried about the side badges behind the front wheels.
I lined them up with my razor sharp eyes :)
In 2016, the US Market got the longer version of the Crossover, here it is Malbec Black in it's transported habitat, Northwest Indiana's Beer Can Beach, Home of Fresh Water Wind Induced Waves that on occasion are Surf worthy, but typically only when frigidly cold. . .   Fair Weather Zed ( we call 'em ZEEs ) also featured in Brickyard in the 1 year only color in 2003
G'day Mates ! ?‍♂️
  • Like 1
  • 3 months later...
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
