yeah looks like it mate. I cannot move forward with the PFC anymore.. I have learnt all i need to know about PFC's.. time to move onto bigger and better things.
haha know that tune well, changing ecu's is always part of evolution and can only ever increase ones skillset.
My car is a car of two halves...
engine... sound system...
Reckon you can tune my subs and see if you can beat the kws I'm getting out of it? :P
just make sure that...
KW > dB
nothing worse than seeing a car with more dB than KW
that would be hard out of a skyline seeing as how the world record is about 180db...
But I'm working on it, don't worry :P
My sound system actually has 3kw of power... pretty weird to think about :D
Yeah... i got many years ahead of me before i catch you trent :P
On your current setup will you be able to go further by just changing the ECU? Where exactly is the PFC falling short?
Yes... The PFC is a great ecu. and it can do my power levels and much more. but seeing that i like to play nutty professor i need something that is more flexible to my needs.
I still love power fc's they are great. But this ecu came up and its time to make the switch, ive delayed it long enough. Hope it all works out.
ecu will be told when its in and working :kiss:
Yeah but WHAT ECU have you changed to???
We're all dieing to know, I'm surprised no-one has asked yet or did I miss something..........
well what ever it is (and ive got a bit of an idea what it could be if Dirt is involved)
you need to post the obligatry anti-lag flames out the exhaust video once uve got it all working haha
but seriously hope it all goes well,
im keen to see how she tunes up, differences you notice, and how all those new features work
ohhh i can do that now with my current setup.. Gizzmo launch controll FTW
GT from what I can see PFC's are fine for doing most of the things that users need in a programmable EMS .
I suppose more specialised uses (ALS/Launch etc) they're a bit limited but for what I want it'll do the job .
Things like the ability to self learn would be useful and I can see this feature becoming more and more important with the way emissions laws are going . If the systems can be made to self tune from basic maps then thats the hardest part for the end user solved .
BTW are you going to continue on with a mass air sensor or are you going to the dark side with an electric barometer ? LOL .
Cheers A .
BTW what system is the EPA using to analyse the exhaust gas , ages ago I remember reading that there is a method of shining a particular kind of light through the gas and by measuring the beam on the other side its possible to see the different levels of certain gasses .
im going over to the dark side mate. I am pretty sure with this ECU i can add a MAF if the MAP sensor pisses me off (this is a very good quality ecu so apparently this will not happen)
As for how the IM240 machine works at the RTA, i have NO idea.
But i do know how the machine reads, what it reads for and whats acceptable levels for whatever car.. I also know what levels are high medium and low when doing the dummy IM240 tests on the dyno instead of the guesswork i have been using previously.
Should be tuning another car for emissions very soon.
Cheers A .
Good to see your dropping the Power FC finally.
Once you have the scope of something better you'll never look back. Id asume what ever your going to be using will be TPS/Map correction like the E11?
Generally I have only ever seen the RTA use a proper 5 gas analiser very similar to the Coda unit that anthony has access to.
Edited by Risking
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
