my magnificent wife complains about the minispool skip.....the fact i always seem to wear out the back tyres...on the good side...she bought me a T04e for valentines day...and entered in a competition which eventually won me a $5000 performance upgrade to my 31......thanks to triple m radio adelaide and D&T performance.....xmas just gone she bought me 4 litres of primer, 4 litres of clear and 4 litres of gunmetal grey metalflake with blue, green and copper pearl in it
nice work on the competition!! that's awesome!!
My missus rekons my car just looks like an old car and is ugly
Mine hates the noise and the ride above all. Though I reckon if someone asked her when I wasn't around she's say everything between the front and back bumpers :(
My ex hated the R33 GTR I used to have and would have hated the R34 too. Every time I drove anywhere I'd have to drive like my mother so she wouldnt get motion sick.
Just my luck to have car that can pull over a G while cornering, but should i drive that way the carpet would need steaming.
pffft it's all about driving smoothly if you get car sickness, doesn't matter how fast it is! :P
my missus loves the 32. she reckons its the hottest car ever. down side is she drives it a fair bit, and she is quite small, and im quite big, so after every time she drives it i spend 20 mins re-adjusting the seat and rear view mirror. another down side is that every time i mention im thinking about selling it and upgrading to a 34, she cracks the shits cos she likes the 32 better.
my gf asks me week by week if my r34 project is finished...and when it will be done, my response is...."its never done and there is always more"
she also whines about how my last 3 birthdays n 1 yr anniversarys i have asked for something for my car everytime...as well as my next dyno tune for $800. score!
otherwise...luv's boost,drifting, banging (on the bonnet of the 34), but says...when ur driving alone just dont kill ur self.
oh and i told her if we ever get married n do the whole kids thing...im moving my running gear to a 4door version....she giggles.
Edited by allthewaytotheskyline
ex hated bumpy suspension when it was stock with just lowered springs so i said guess what im buuying next coilovers made her hate it even more and prety much complained about every other thing everyones said spend to much money etc, ahahahha going back to single was the best choice i ever made with adding plenty of mods now if u drive a import tuner you gotta go out with your car cause it never stops ahahah buying shit
My old lady pretends to hate my car but she's the first one to offer advice on any new mod.
Being a woman its all about the vis. If it doesnt meet with her approval I get threatened with. "I'm not driving around with that on the car"
Wish I could find more "that" :(
mine STILL keeps whinging about the TE37's, so I told her to STFU, after patiently explaining why they are superior to $1000 bob jane specials. At least my mates GF's listen to them about cars lol. Still trying to drum into her head that Japanese cars are NOT meant to look like Fast and the Furious lol.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
