The R34 test rig is in progress and will be tuned with the latest SS2 prototype this friday, hopping for 300rwkws+ with 20psi by 3500RPM.
Just saw that and my pants tightned slightly lol
  • Like 1
Hey Tao I saw the ATR45SAT results on the standard rb26. 400kw 24psi e85. Boost comes on barely behind the standard twins! Did you have adjustable cam gears at all?
I look forward to fitting that
turbo to the 2630. I'm picking up the short block in the next few weeks so I should organise the turbo + 50mm gate asap
With the new SS2, the original print is based on the 21U high flow, except I have the freedom of using larger internal gate and different types of wheels, it is very promising.
The Rb26 ATR45SAT result, is from a unopened Rb26 engine using factory cams and cam gears. It drives extremely well on road, picks up boost nice and early in low gears and respond extremely well to throttle just like stock turbos. This turbo is designed for standard RB26 engines. By adjusting cams gears, responds should be improved that could possibly match the standard T25s.
Edited by hyper-gear
  • Like 1
Right, I've got fuel pump, clutch and injectors, all I need now is the turbo.
I was originally going for 300ish rwkw so was looking at the SS2, however the car is not a daily so why not shoot for something higher? That would be the G3 I believe?
Is there a guide on what's required to fit the G3, Stao? I will be taking it to one of the local guys for fitting so want to make sure they have everything required to get it on.
Also, what's the best way to go about making said purchase?
If its for a Neo motor, I will recommend our ATR43G4SAT model. That turbo wold be good enough to hit close to 350rwkws pump internally gated. Cost same as the G3, you can find it on our site under the ATR43 page. cheers
Hey cowboy, if its not your daily. Might i reccomend instead of doing that. Why not just go for say the 21u or the op6 On full e85? Both have seen over 300 fair easy on e95 with basic bolt ons? Just a thought :)
I've put a lot of thought into E85, and really want to go down that path, but I think that'll have to come with a flex tune one day. For now I'm going to stay pump. I sized my injectors to give me the capacity to go E85 one day.
It is for a Neo.
Is it basically bolt on?
Yes, Check my last result from a month ago. made 311rwkws on 20psi with a cooler restriction with pump fuel. It can be made as a bolton turbo. Cost $1250 inc oil line.
Is this what I need to order?
OMFG, finally, it is done.
After talking about it for what seems like years I've finally put down some cash.
ATR43G4 Ordered!
Now just need to get it all fitted.
I have the following:
Walbro 460
Id1000s
Split fires
Car already has fitted:
Exhaust
Front mount
PFC
CAI
EBC2
Iridiums - will gap down to 0.8mm
Anyone see anything I've missed?
I'm shooting for 320+ on pump.
ATR43G4 Ordered!
Walbro 460
Id1000s
Split fires
Exhaust
Front mount
PFC
CAI
EBC2
ditch the iridiums and get bcpr7es plugs.
  • Like 1
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
