Hypergear Turbochargers and High flow Services Development thread
You could be retarded like me and buy a standalone ECU for the gearbox..
Or be like my current better half who just learned to drive manual
What did you get? How does it perform?
Ur right dose pipe you can pigy back tho has to b a good stand alone tho i did hear you can use a r34 computer and go nistune to how true this is im unsure
R34 like S2 Stagea has a different plug. People usually just get something like a Greddy Emanage, HKS F Con or even a Link and interrupt the appropriate wires.
Adaptronic e420d are cheaper in the long run and Tao has the best price in Australia. Msg Tao and ask him how much.
The greddy is old tech and you need to buy a whole lot of add ons to get to where the adaptronic is.
Tao, my early 2012 SS2 appears to have done a compressor seal. When I pressurized the manifold it leaked out almost the whole way round the seal.
What's it gonna cost to fix that and any upgrades you would recommend?
The seals in turbos steel C clips. They are not an liquid tight seals. Unless there are measurable back n forward play, those seals won't wear, and if its also not leaking when the engine is running its most likely to be alright.
Most of turbo drain system relays on gravity. When crank case pressure is applied, oil will be forced out of both compressor and turbine seals.
If there is an measurable back n forward play it would require an rebuild. Assume all it needs is an bearing kit, I will charge you $100 to carry out.
The current SS2 is very different to what it was, it makes a lot more power without losing response, specially for externally gated application. But that will require a new build and I'm happy to look after you on the pricing.
Ah good, there is no play in it, just weeping air out the seal when compressor was pressurized. Wasn't leaking enough to hear but could see when spraying soapy water on it.
Found 7 boost leaks and 1 vacuum leak on the car so hopefully it's a completely different beast now.
Thanks for the offer but I'm quite happy with its performance and will stick with it.
Edit- and the crankcase circuit wasn't pressurized so the oil seals are fine :)
Alrighty update time, I've installed the new revised SS2 with the Ceramic Ball Bearing CHRA... and... holy fuark me it's amazing.
I was too lazy to touch up the tune but it's rich enough to be thrashed *cough* I mean tested lol.
I'm now able to get nearly 1.4 bar in 2nd gear! where with the old circa 2012 SS2 it would barely get 1.2 bar in 2nd. In 3rd shit just gets silly, I'm getting nearly all 1.6bar in around 4200rpm according to the inaccurate OEM tachometer.
I'll plug in the laptop for some logs soon for those data junkies.
A few things with the new CHRA, it's so much easier to install as you're able to bolt up the turbo without needing to remove the front cover like the old SS2. However the turbo sits lower so I need to cut my dump and weld it back up also the oil return need a slight bend to line up other than that it's nearly plug and play.
  • Like 2
Drifting video from Jason.F's R31 Wagon. This particular project has a very unique CBB turbo build on getting most reponsive 320rwkws out of none VVTI 1JZ. It has been a challenge dealing with back pressure and took a few try to get working.
  • Like 4
Sounds awesome, glad someones havin some fun...
Vids of skids and teh su.. su.. su.. sututututuutut...
    • I have been looking at some setting on the alarms for the Q60 and what buttons do and so and also been looking for details on the alarm in my V37 which is a standard issue with the car. settings like window roll up and a few others seem to not work at all. i cant seem to find exact info on V37 alarms so Q60 is all i can really go off i have not tried 400Z alarm settings or info yet so that will be next. any one got like a sheet of info on the alarm system in the V37 as all my documents are in japanese but i thought the system would basically be like standard through similar models?
    • I had a fuel smell coming from the drivers rear and pulled the tank out to inspect where it was coming from, turns out the breather hose from the tank to the filler neck was perished. I’m going to Japan next week and I’ll grab it while I’m there  pulled the oil tank apart and started cleaning this crap out of it, some brake cleaner and rags got it looking new again
    • Hmm. Was quite a few years ago now. I think I bought from a crowd in the US called CDT Audio. The speaker is the HD-6. The HD-6CF would have been the better option (based on T-S parameters), but they were discontinued in 4 ohm at that point in time. The HD-6 is a better driver in almost every other way (than the CF) - just not as good in IB. They still do the HD-6. They might even have a more suitable (for IB) option here.https://www.cdtaudio.com/cdtnew22/products/components/woofers/midwoofers/midwoofers.htm But, here's the rub. I was working in the US a lot back then, so I got them delivered to my US office and then just brought them back to OZ myself. I don't know if they will ship to OZ, and it probably wouldn't be great cost-wise anyway. As to results. They're driven direct off the rear channels of my headunit, because the headunit can be setup to run the rears as subs. So, not a lot of power being fed there. Nevertheless, there's no shortage of volume - the sub levels don't need or want to be boosted at all. The bass is definitely not what you would call "tight". It is definitely a bit delayed compared to a proper sub. But, with the great front soundstage and really good 6.5" woofers in the front doors, I'm getting most of the bass detail from the front and the rear is really only to extend the bottom end a bit. Works for what I'm doing. I mean - until recently you couldn't really hold a conversation in my car due to the fuel pump, and for many years I had tyres so noisy (Kumho KU36 at <50 tread depth) that I had to drive with earplugs anyway!
    • curious to know what drivers you chose and the results? quik mafs, says two 6.5s should roughly equate somewhere between a single 8" or 10" driver. i agree that IB is definitely the way to go in most cars imo.
    • S13 and R32 rear suspension geometry is horrible once you lower it (which everyone does). The camber & toe out ramp is very aggressive, hence it's common for the S13 boys/girls to use a S14 or S15 subframe as the geometry is light years ahead. I'm sure the same can be done on R32s, but I don't know anyone that has done that.
