You get full boost by 4300RPMs with RB25det using .82. It pulls lot harder.
If your purposes of buying this turbo is for mild power street use the .63 is fine, But it does get really hot under high boost if you use it for drifting or tracking.
Another small update:
Still remember this ATR43G3 unit with .82 turbine and .70 comp?
Got it dyno tuned today, car mad 298.5rwkws on 21psi with miss-fire. Only done 2 runs, car miss-fired very bad after, we changed plugs cleaned coils and nothing helped. I will give another try with splitfire coils in few weeks. I didn't grab the dynosheet this time. But dyno footage with 3 people in the boot is worth to look at:
(click on photo below to watch that video footage)
Also my engine comp shown:
130, 125, 125, 120, 125, 119
Next run will be with a new forged engine :miner:
nice power how much for the turbo? and what mods does it require to bolt up
Peak power was around 7000RPM. Check the 2nd run with people in the boot.
Power rise till red line, the curve is very similar to the 268rwkws run with restrictive intake and the 316rwkws run on with the sil180.
car was not strapped with wheel spin, Reved to 7000RPM as usual.
Next run will be with a new forged engine :)
These are the ones i wanna see more of :) 0.82 has a better power torque balance than 0.63.
I think this turbo is the same as my ATR28g4. Getting slightly better spool now with my alternator changed. Hitting 1 bar just after 4000rpm with no boost controller. 10psi Actuator with heap of preload
Further updates:
Apart from turbochargers our engineers are also dedicated in to engine building, how ever I'll not provide this service to the public. I will show every one how it’s done and costs involved. Any useful advise is welcomed.
Primary goal:
This engine will be used for our turbocharger evaluation pusposes, My goal is 350rwkws.
This engine will be built with stock cams using forged pistons only, so Power vs Boost generated from it would be identical to any other healthy standard RB25dets.
Engine:
96 model RB25det engine bought from local wrecker.
An hour later its in bits:
Cracked piston in cyc 6. But bore seems to be in ok condition
I’ll be using forged CP 20 thou over sized RB25det pistons with rings and pins. The piston set cost $1150 AUD.
Engine block's been sent away to Reflex engine services. Its going to cost $260 to re-bore all 6 cyc with block thermo bathed. Engine head cost $250 to trim and bath.
Also for people whom owns a pair of CT12a Powered 1JZ Soarers. We can high flow them to 2860rs Disco CHRA specifications in sleeve bearing:
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
