Good intake pipes aye. The 3 inch metal pipe fits snug inside it so not restricting it.
I Can supply if u like
There was no issue's with holding boost. Just how i set it up with the boost controll. Car feels like more than 200kw on the road.
It does feel really fast. And to think I got so much advice before I highflowed to get a bigger turbo, but I love the response of this unit.
Nice and torquey too
Fun!
Where did you get this intake pipe? I need a few my self.
In this case not sure if by using high pressure actuator holding more boost uptop would gain abit more kws, but that would be about the limit from high flowing a R32 GTT turbo.
I have a GCG highflowed R32 rb20det turbo that makes about ~235kw on 18psi dropping to 15psi by redline on an rb25det. Can hold 18-20psi to redline just haven't had a chance to get it tuned with that to see what it can make. I am 100% sure it is an rb20det turbo so you could probably squeeze a slightly bigger rear wheel in there if they managed to.
It has the valve on the compressor housing?
The Rb20det's high flow profile is smaller then what we normally do on RB25det. it can be made bigger, how ever the drivability would turn bad as its missing 0.5L and no VCT enhancing down low.
Rb25det would make power lot easier, Rb20dets are generally 20% behind in power.
I'm quite happy with how do the RB20 high flow :)
Tis a neat looking pipe. Can I assume correctly that this should fit an RB25 all the same? If so, what would you sell one for?
Isnt that intake pipe just a bit of straight 3" pipe with 2x45 degree silicone bends cut to the right lengths?
I would be a little bit worried about the silicone bends bending under cornering and acceleration load. Mine just uses a 90 degree metal bend but with fittings welded on so that the bov and pcv lines can be attached.
does that look like a metal intake pipe to you? :glare:
any competent exhaust shop can make up an intake pipe for you.
should cost anywhere from $100-$150~
yes it does..when you know how to look further.......cut that silicon sucker in half, get a short length 3" metal pipe and put those 2 'joiners' on both ends.. easy isnt it?? Thats how you create a backyard metal intake pipe that should work - refer cherring's car a page earlier on this thread.
Edited by rondofj
I was set out to make my own and after figuring it out its not too hard. To use all your stock oil breather and BOV return, just get a 3" metal intake pipe with 90degree bend, stick it in the front of the turbo and cut the breather and return where they touch the pipe. The pieces you cut off form the nipples to attach your shit back onto. Any workshop will charge little to nothing to weld these on(if you know someone with the welder).
Don't bother trying to make any fancy bends to fit shit. Trust me a 3" 90degree pipe fits the z32 and apexi filter snuggly.
if you're gonna spend $60 on this + 3" pipe to cut and fit in, why not just do that with the stock intake pipe, its been done many times before on here, theres even a DIY thread about it.
I did read somewhere that even with the $10 intake mod (stock pipe cut in half with metal pipe stuck in the middle), those rubber bends STILL suck close and dont work for everyone...
Both are pointless and shit ideas. I tried the half metal half stock(the bigger end). According to Tao, this is a loss of 65rwkw from back to back tests he done. I made 244rwkw. Add 60rwkw you get 304rwkw from the SS2. Ive got it sorted now, full 3" metal just need a retune.
Good idea - I was also thinking of using a 3" 90 deg bend from supercheap for $27 something and get an exhaust place to weld on those annoying breather nipples..just worried about the fit..
Ooops -thats actually a 45 deg piece, they do have them 90deg pieces in aluminium
Edited by rondofj
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
