Good intake pipes aye. The 3 inch metal pipe fits snug inside it so not restricting it.
I Can supply if u like
There was no issue's with holding boost. Just how i set it up with the boost controll. Car feels like more than 200kw on the road.
It does feel really fast. And to think I got so much advice before I highflowed to get a bigger turbo, but I love the response of this unit.
Nice and torquey too
Fun!
Where did you get this intake pipe? I need a few my self.
In this case not sure if by using high pressure actuator holding more boost uptop would gain abit more kws, but that would be about the limit from high flowing a R32 GTT turbo.
I have a GCG highflowed R32 rb20det turbo that makes about ~235kw on 18psi dropping to 15psi by redline on an rb25det. Can hold 18-20psi to redline just haven't had a chance to get it tuned with that to see what it can make. I am 100% sure it is an rb20det turbo so you could probably squeeze a slightly bigger rear wheel in there if they managed to.
It has the valve on the compressor housing?
The Rb20det's high flow profile is smaller then what we normally do on RB25det. it can be made bigger, how ever the drivability would turn bad as its missing 0.5L and no VCT enhancing down low.
Rb25det would make power lot easier, Rb20dets are generally 20% behind in power.
I'm quite happy with how do the RB20 high flow :)
Tis a neat looking pipe. Can I assume correctly that this should fit an RB25 all the same? If so, what would you sell one for?
Isnt that intake pipe just a bit of straight 3" pipe with 2x45 degree silicone bends cut to the right lengths?
I would be a little bit worried about the silicone bends bending under cornering and acceleration load. Mine just uses a 90 degree metal bend but with fittings welded on so that the bov and pcv lines can be attached.
does that look like a metal intake pipe to you? :glare:
any competent exhaust shop can make up an intake pipe for you.
should cost anywhere from $100-$150~
yes it does..when you know how to look further.......cut that silicon sucker in half, get a short length 3" metal pipe and put those 2 'joiners' on both ends.. easy isnt it?? Thats how you create a backyard metal intake pipe that should work - refer cherring's car a page earlier on this thread.
Edited by rondofj
I was set out to make my own and after figuring it out its not too hard. To use all your stock oil breather and BOV return, just get a 3" metal intake pipe with 90degree bend, stick it in the front of the turbo and cut the breather and return where they touch the pipe. The pieces you cut off form the nipples to attach your shit back onto. Any workshop will charge little to nothing to weld these on(if you know someone with the welder).
Don't bother trying to make any fancy bends to fit shit. Trust me a 3" 90degree pipe fits the z32 and apexi filter snuggly.
if you're gonna spend $60 on this + 3" pipe to cut and fit in, why not just do that with the stock intake pipe, its been done many times before on here, theres even a DIY thread about it.
I did read somewhere that even with the $10 intake mod (stock pipe cut in half with metal pipe stuck in the middle), those rubber bends STILL suck close and dont work for everyone...
Both are pointless and shit ideas. I tried the half metal half stock(the bigger end). According to Tao, this is a loss of 65rwkw from back to back tests he done. I made 244rwkw. Add 60rwkw you get 304rwkw from the SS2. Ive got it sorted now, full 3" metal just need a retune.
Good idea - I was also thinking of using a 3" 90 deg bend from supercheap for $27 something and get an exhaust place to weld on those annoying breather nipples..just worried about the fit..
Ooops -thats actually a 45 deg piece, they do have them 90deg pieces in aluminium
Edited by rondofj
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
