Birds Posted March 27, 2012 Share Posted March 27, 2012 Should be picking my car up tonight... Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6291848 Share on other sites More sharing options...
Manuel Kasko Posted March 27, 2012 Share Posted March 27, 2012 Hell yeah birds can't wait to see results to compare! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6291867 Share on other sites More sharing options...
hypergear Posted March 27, 2012 Author Share Posted March 27, 2012 Its been a while seeing the Greedy copies around with few good working examples. So we've imported few. The first one I'm interested to try is the TD06SL2 in 10cm with T3 flange turbine housing running our re-trimmed 20G Billet compressor wheel. It has been pulled apart and rebalanced (tolerance is about twice higher then where I normally set them to, its now corrected). to make sure every thing can work accordingly. Those turbos are externally gated only and available to every one for $850 including GST and 12 month local warranty. I will refer to it as the EXGBTD06SL2 Looking through the turbine design, it appears been able to make plenty of torque, but I'm not too sure about response. There is also room in FNT turbine upgrade. I might be able to adapt internal gate onto it with the Nissan 6 bolt flange. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6291944 Share on other sites More sharing options...
Rolls Posted March 27, 2012 Share Posted March 27, 2012 I might be able to adapt internal gate onto it with the Nissan 6 bolt flange. This would be very interesting to see results for as the current IG kandos suck a bag of dicks. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6291954 Share on other sites More sharing options...
jet_r31 Posted March 27, 2012 Share Posted March 27, 2012 This will be interesting.... cheers darren Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6291982 Share on other sites More sharing options...
rondofj Posted March 27, 2012 Share Posted March 27, 2012 Its been a while seeing the Greedy copies around with few good working examples. So we've imported few. The first one I'm interested to try is the TD06SL2 in 10cm with T3 flange turbine housing running 20G Billet compressor wheel. It has been pulled apart and rebalanced (tolerance is about twice higher then where I normally set them to, its now corrected). to make sure every thing can work accordingly. Those turbos are externally gated only and available to every one for $850 including GST and 12 month local warranty. I will refer to it as the EXGBTD06SL2 Looking through the turbine design, it appears been able to make plenty of torque, but I'm not too sure about response. There is also room in FNT turbine upgrade. I might be able to adapt internal gate onto it with the Nissan 6 bolt flange. Nice.. Why not call it HG TD06SL2 (Hypergear TD06SL2), thats less confusing.. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6291987 Share on other sites More sharing options...
hypergear Posted March 27, 2012 Author Share Posted March 27, 2012 I'm pretty interested in this turbo on Ron 98. or does any one got a dynosheet from Kando's version of it running pump 98? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292027 Share on other sites More sharing options...
Rolls Posted March 27, 2012 Share Posted March 27, 2012 Think there are some in the kando thread Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292036 Share on other sites More sharing options...
hypergear Posted March 27, 2012 Author Share Posted March 27, 2012 I had a look through they all appears to be in E85. Shouldn't be too much problem, I can run it with E85 also. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292052 Share on other sites More sharing options...
DVS JEZ Posted March 27, 2012 Share Posted March 27, 2012 This is internal gate, no boost controller, no vtc. Will finish this one off next week when the window switch arrives. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292056 Share on other sites More sharing options...
ARTZ Posted March 27, 2012 Share Posted March 27, 2012 Looking through the turbine design, it appears been able to make plenty of torque, but I'm not too sure about response. There is also room in FNT turbine upgrade. I might be able to adapt internal gate onto it with the Nissan 6 bolt flange. I take it you dont follow the kando thread cause this is what I have been saying for months... If you want a ride in my car just PM me man,...clutch is slipping a little atm but should be rectified soon.. Car is very nice smooth to drive @ 1 bar boost, with 6 month old fuel that was still sitting in my tank.. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292077 Share on other sites More sharing options...
hypergear Posted March 27, 2012 Author Share Posted March 27, 2012 Yea I found it. It looks too linear thou, I pictured it would do some thing that. I should be able to add in lots of meat into the mid range with FNT turbine. Where abouts are you based? I'm testing the ss1pu again Friday afternoon which we can swap cars for a test drive near status or unless if you are in the North side. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292112 Share on other sites More sharing options...
Rolls Posted March 27, 2012 Share Posted March 27, 2012 He is only running 1 bar, run 20psi and have it taper down and the midrange would be massive. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292120 Share on other sites More sharing options...
scotty nm35 Posted March 27, 2012 Share Posted March 27, 2012 Yea I found it. It looks too linear thou, I pictured it would do some thing that. I should be able to add in lots of meat into the mid range with FNT turbine. Where abouts are you based? I'm testing the ss1pu again Friday afternoon which we can swap cars for a test drive near status or unless if you are in the North side. There is no midrange because its at one bar, lets wait and see what the 22psi graph looks like. Hurry up and get that clutch in Artz. I'm interested to see the results with the stock 5 bolt housing. Get on to it Stao. An M35 Stagea rear may work well too... Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292134 Share on other sites More sharing options...
ARTZ Posted March 27, 2012 Share Posted March 27, 2012 Yea I found it. It looks too linear thou, I pictured it would do some thing that. I should be able to add in lots of meat into the mid range with FNT turbine. Where abouts are you based? I'm testing the ss1pu again Friday afternoon which we can swap cars for a test drive near status or unless if you are in the North side. yeah cool, Im near dandy..I probably cant get there till about 6 though will you still be around? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292159 Share on other sites More sharing options...
hypergear Posted March 27, 2012 Author Share Posted March 27, 2012 I'll be there 7pm starting the tune on Friday. Its more of testing the wastegate actuator and a newer housing. Should all finish in an hour so its all good if you like to come in around 7pm and see how the tunning goes. I will trail some externally gated ones including the SL2 and T67 combinations with billet wheels and do some modifications no housings from there. At this stage we can supply SL2 units in 10cm T3 turbine with billet compressor wheel. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292180 Share on other sites More sharing options...
ARTZ Posted March 27, 2012 Share Posted March 27, 2012 no worries.. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292203 Share on other sites More sharing options...
Manuel Kasko Posted March 27, 2012 Share Posted March 27, 2012 Anyone got ideas about what I should be saving for next to get a bit more put of the turbo Also how do I get rid of the ping around 250kw Do things like oil coolers keep the overal engine temp down to prevent this? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292220 Share on other sites More sharing options...
zebra Posted March 27, 2012 Share Posted March 27, 2012 Water Meth Injection better (more efficient) intercooler Freer flowing exhaust there are a few things you can do to squeeze every last drop out, but $$$ per HP makes it rather expensive Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292236 Share on other sites More sharing options...
hypergear Posted March 27, 2012 Author Share Posted March 27, 2012 Anyone got ideas about what I should be saving for next to get a bit more put of the turbo Also how do I get rid of the ping around 250kw Do things like oil coolers keep the overal engine temp down to prevent this? Save for a plazaman cooler. Or a custome side mount manifold Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/222/#findComment-6292280 Share on other sites More sharing options...
