Sucks about your clutch
Question for stao. Where do you turbine wheels come from?
As for reliability look what happened with the bw efr turbos
Manufacturing faults can and will happen
Just to give you an idea. I've had a 21U hi-flow for a while now. Over 45 track days down, pulled it off late last year and it looked perfect.
Birds did you go the 10"? For around the $650 mark?
I got a quote yesterday for one and the guy said its rated to around 400rwhp
Yer it was the 10. Bolts up to standard flywheel so that's a big plus. Wait til I tell my girlfriend I've got a 10" now!
Might be a stupid question, but where abouts are these clutches power ratings being measured at? If its only a 400hp clutch I hope it's at the wheels, but that seems like an odd place to measure it from for a clutch
Edited by Mitcho_7
They would be measured at the flywheel but you could give a rough estimation for how much wheel kw it can hold.
Well if the clutch is only going to hold 400hp at the flywheel wouldnt that be barely enough clamping force for the guys with the ss1pu's that have 250kw at the wheels?
??? In both Kasko and my posts, we refer to rear wheel power...
I'd rather they be measured at the wheels, that seems more practical to me given all our dyno readings are obtained there.
I didn't see the rear wheel part. If you guys manage to get your boost fixed up top and get say an extra 20kw you'll be closing in on 400rwhp won't you?
They tell me it's good for 300rwkw, so I'm going off that. Doubt I'll touch on 300rwkw...even with E-flex...my compressor housing is too small.
Im not saying its a bad cluth choice for youre power im merely asking Is 20-30rwkw enough wiggle room in terms or clamping force once the clutch wears abit? I'm interested to know is all.
I think you will be surprised Birds, and the torque hike will only make it worse.
Guess we'll find out, but it's a risk I'm willing to take. Worst case scenario I flog it off to someone who has less power and opt for the not-so-pleasant-sounding alternatives: fork out $$$$ for a JB, put up with the violence of an HHHDB, or do both of these things and get a twin plate.
I'm not drifting/racing the thing, I just want a clutch with enough clamping pressure to hold things together under load during the daily drive with the occasional spurt...I think it'll do the job fine. Keep in mind these power ratings are only a guide...there's no point splitting hairs over 300rwkw, not like the thing will magically pop just after 299.9rwkw and I don't think NPC would be selling their clutches based on power ratings if they weren't a tad conservative.
NPC Twin plate ;)
Talking to a mate the other night who has one, he reakons its the best clutch he's ever used. I'm half kicking myself I didnt just get one from the start, but oh well, I'll see how long the 10" single plate lasts. So far its been great but :)
NPC Twin plate ;)
How long has it already been in there?
When I spoke to NPC he said his mate was running one in a 300kw car so it should be fine
Same with the quote from KB clutches
He asked for my peak power/torque and what rpm it makes these by.
He then spent a few hours and got back to me with the organic
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
