Have you done the SS1pu on e85 yet?
Would be really interested
Really not liking the idea of always having to run 20psi to get 250rwkw when these other turbos that people are strapping on are making simple 240 etc on lower boost such as 16-18psi
Pm me or post up here if you could
Cheers mate
Aside from where it's sold, can you think of any reason why not to as a tuner?
It makes their job too easy, no challenge, as it's not on the verge of knock all the time. :)
Seriously, the only reason not to run it is the extra fuel it requires, larger fuel system, less k's to the tank. The positives outweigh the woeful economy tenfold. Clean engine, more torque/power, lower temps, cheaper, environmentally friendly, not having to line the pockets of thieving oil companies...
Shhhhhh. :D
Haha copycutter availablity is the only issue. Oh and supposedly it melts fuel rails and ruptures fuel lines etc etc according to people that dont like ethanol for some stoopid reasons
Shhhhhh. :D
Hurry up Penrith E85 pumps!
I might be wrong but how is running e85 cheaper?
its $1.18 vs $1.50 at the moment. and say it burns 30% more $1.18 is equivalent to $1.53 in petrol cost. so not cheaper now but the power gains is a benefit for virtually the same cost. but when 98 goes up which it will, you will save.
O_o. Plus a new fuel system. So I guess it's much like gas. Some people will do it thinking oh this is a great idea and the rest will just continue on with their lives. Although I was told that the only way my hypergear will be reliable is with e85 as it heat soaks really bad. In that perspective I can see why stao is listing the e85 figures. Let's get some more dyno sheets in here already. Any more testing done yet?
E85 won't be +30% if you do mainly highway of say 80km/hr+ kms... my GT-T got to +10-15% on 98 fuel economy with E85 and that was back when E85 was 97cents a litre... was much winning :D
and to the person thinking of going z32 ecu nistune - i think change your ecu plans, FC or Link plugin. Nistune is great, and i highly recommend it... but for 33 owners, there are better options.
You know there's a United with E85 at the top Old Bathurst Rd in East Blaxland now? That's only 6 or 7km out of Penrith
Surely the 'Riff will get one soon.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
