Turbo feels like it will make heaps of power and feels pretty responsive considering I doubled the a/r on the exhuast housing. Might boost it to 12psi to see if theres a big change. I just can't believe how well the tial controls the boost. Nothing comes out The screamer until like 9-9.5 psi.
Did a naughty today and gave my car some full boost in a couple of gears to test the new clutch; I'm supposed to be running in a gearbox...
Fark me, not sure if I'll need E-flex straight away. On the freeway ramp 2nd took me there so fast I couldn't even enjoy it lol. And third gear roll from 80km/h is ridiculously good fun. <3 SS1PU
Now to be good for the rest of my gearbox run in period :/
Fark me, not sure if I'll need E-flex straight away. On the freeway ramp 2nd took me to 100 so fast I couldn't even enjoy it lol. And third gear roll from 80km/h is ridiculously good fun. <3 SS1PU
Lol..yeah i was amazed how fast my car actually was with a decent clutch installed too.... anything over 4000rpm just gets scary now :laugh:
Can't wait to see the tune results
Stao, have you ever thought about doing a twin scroll turbine housing or are they too expensive to produce?
The turbo is not expansive to produce. all I have to do is slot the .82 rear housing in the center and insert an divider then profile the housing to suit turbine wheel, and we have a real twin scroll turbine housing. How ever it must be used on a twin scroll manifold as well external gate (preferably 2).
any chance of a internally gated twin scroll? I'll be down for that!
Didn't KKR produced a twins scroll internally gated turbine housing for their KKR480 and 560 turbos years back? It ring a bell as I have read many complaints about their lack in ability of boost control.
Wouldn't surprise me if they struggled with boost control. There is probably a reason you don't see many, if any twin scroll internally gated turbine housings
Edited by Mitcho_7
EVOs, STIs run internally gated twin scrolls. I just want it for simplicity & the "kinda" stock look instead of 2x gates hanging off the manifold.
Yeh, itd definently be worth a try i think, providing you can get it to control boost well. Sure as hell beats having to fiddle with plumbing up two external gates in that limited space.
Edited by Mitcho_7
One external gate is fine if you run the splitter right up to the gate valve.
I just don't think there is room to effectively flow the gasses on internally gated housings, other than the BW, they nailed it, but it makes the rear housing too large.
picka-boo TiAL :D ... pretty happy with the end result.
only on 10psi at the moment but holds dead flat, car is alot faster and spins all off second if i dump the clutch which it wouldn't do before.
Booking a tune at Chequered Tuning next week, aiming for 280rwkw at 18-19psi
do you have photos of the manifold? I'm curious :)
Just Google rb25 manifold lol. I haven't done anything to manifold. The external gate is off the rear housing. It was cheaper, easier, and I could use my factory crossover pipe with no mods. Just have to chop up the heat shield a bit.
LOL
got photos of the rear housing?
derrrr a few pages back lol nvm... I notice the internal gate is still there??
Edited by johnnilicte
Haha. Dual gate is true. But the internal one is locked of with a pin and is nice and sealed. I did it so I have better resale value as well as the option to use it for EPA excuses/rectification and the most important reason for me, bolts to existing dump pipe. Nice and easy
Just got to read from the photos onwards
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
