Turbo feels like it will make heaps of power and feels pretty responsive considering I doubled the a/r on the exhuast housing. Might boost it to 12psi to see if theres a big change. I just can't believe how well the tial controls the boost. Nothing comes out The screamer until like 9-9.5 psi.
Did a naughty today and gave my car some full boost in a couple of gears to test the new clutch; I'm supposed to be running in a gearbox...
Fark me, not sure if I'll need E-flex straight away. On the freeway ramp 2nd took me there so fast I couldn't even enjoy it lol. And third gear roll from 80km/h is ridiculously good fun. <3 SS1PU
Now to be good for the rest of my gearbox run in period :/
Fark me, not sure if I'll need E-flex straight away. On the freeway ramp 2nd took me to 100 so fast I couldn't even enjoy it lol. And third gear roll from 80km/h is ridiculously good fun. <3 SS1PU
Lol..yeah i was amazed how fast my car actually was with a decent clutch installed too.... anything over 4000rpm just gets scary now :laugh:
Can't wait to see the tune results
Stao, have you ever thought about doing a twin scroll turbine housing or are they too expensive to produce?
The turbo is not expansive to produce. all I have to do is slot the .82 rear housing in the center and insert an divider then profile the housing to suit turbine wheel, and we have a real twin scroll turbine housing. How ever it must be used on a twin scroll manifold as well external gate (preferably 2).
any chance of a internally gated twin scroll? I'll be down for that!
Didn't KKR produced a twins scroll internally gated turbine housing for their KKR480 and 560 turbos years back? It ring a bell as I have read many complaints about their lack in ability of boost control.
Wouldn't surprise me if they struggled with boost control. There is probably a reason you don't see many, if any twin scroll internally gated turbine housings
Edited by Mitcho_7
EVOs, STIs run internally gated twin scrolls. I just want it for simplicity & the "kinda" stock look instead of 2x gates hanging off the manifold.
Yeh, itd definently be worth a try i think, providing you can get it to control boost well. Sure as hell beats having to fiddle with plumbing up two external gates in that limited space.
Edited by Mitcho_7
One external gate is fine if you run the splitter right up to the gate valve.
I just don't think there is room to effectively flow the gasses on internally gated housings, other than the BW, they nailed it, but it makes the rear housing too large.
picka-boo TiAL :D ... pretty happy with the end result.
only on 10psi at the moment but holds dead flat, car is alot faster and spins all off second if i dump the clutch which it wouldn't do before.
Booking a tune at Chequered Tuning next week, aiming for 280rwkw at 18-19psi
do you have photos of the manifold? I'm curious :)
Just Google rb25 manifold lol. I haven't done anything to manifold. The external gate is off the rear housing. It was cheaper, easier, and I could use my factory crossover pipe with no mods. Just have to chop up the heat shield a bit.
LOL
got photos of the rear housing?
derrrr a few pages back lol nvm... I notice the internal gate is still there??
Edited by johnnilicte
Haha. Dual gate is true. But the internal one is locked of with a pin and is nice and sealed. I did it so I have better resale value as well as the option to use it for EPA excuses/rectification and the most important reason for me, bolts to existing dump pipe. Nice and easy
Just got to read from the photos onwards
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
